lm reactor raz
(31.01.2017, 20:12)Erwin van der Zwart Wrote: Hi,
The SD card is internal on the board, you have to open the device to reach it.
Reset button to factory settings, you have to press it 10 seconds (you see the LED red), release and press direct again for 10 sec (you see LED red flash), release again and press direct again and press 10 seconds. The device will reboot after a small period, just be patience...
However as admin say's SD is in read only mode, the reset will probably not work...
thanks... yes reset not work.
ok for opening, bad news, i'll unplug all IO wires.
not very easy, on LM reactor wire connectors are not very very good quality after unplugged
lm reactor raz - by 69jtdti - 30.01.2017, 22:29
RE: lm reactor raz - by admin - 31.01.2017, 07:32
RE: lm reactor raz - by 69jtdti - 31.01.2017, 12:21
RE: lm reactor raz - by admin - 31.01.2017, 12:35
RE: lm reactor raz - by 69jtdti - 31.01.2017, 19:56
RE: lm reactor raz - by Erwin van der Zwart - 31.01.2017, 20:12
RE: lm reactor raz - by 69jtdti - 31.01.2017, 20:38
RE: lm reactor raz - by 69jtdti - 04.02.2017, 18:21
