Modbus profiles examples
#74
I used a scheduled script to read the modbus register. In the device instructions it's indicated that I must repeat the reading in case of error. I attach the script that I used to detect if there is an error. It doesn't work. Can someone help me, please?
nappartamento = grp.getvalue('32/1/2')
nappartamento = nappartamento + 1
if (nappartamento > 211 ) then
nappartamento = 200
grp.update('32/1/2', nappartamento)
log(nappartamento)
require('luamodbus')
mb = luamodbus.rtu()
mb:open('/dev/ttyUSB0', 9600, 'N', 8, 1, 'H')
mb:connect()
mbConfusedetslave(32) --CENTRALINA MASTER
--IMPOSTO LETTURA NAPPARTAMENTO
contatore1=1
mb:writeregisters(7, nappartamento)
os.sleep(10)
--RIPETO SE RISPONDE CON ERRORE 5 VOLTE
contatore1=1
while (contatore1 > 0) do
  res, err = mb:readregisters(7, nappartamento)
if not res then
    os.sleep(30)
  contatore1 = contatore1 + 1
  if contatore1 > 5 then
      alert('errore1')
    return
else -- TUTTO OK
contatore1=0
mb:writeregisters(6, nappartamento)
os.sleep(35)
contatore2=1
while (contatore2 > 0) do
  res, err = mb:readregisters(6, nappartamento)
if not res then
    os.sleep(30)
  contatore2 = contatore2 + 1
  if contatore2 > 5 then
      alert('errore2')
    return
else -- TUTTO OK
contatore2=0
-- LEGGO VALORI
--log(mb:readregisters(3015,8))
os.sleep(1)
calorieh,caloriel,frigorieh,frigoriel,acs_lo,afs_lo,acs_hi,afs_hi = mb:readregisters(3015,8)
calorie = caloriel + (calorieh*65535)
log(calorie)
frigorie=frigoriel + (frigorieh*65535)
log(frigorie)
acs=acs_lo+(acs_hi*65535)
log(acs)
--afs=afs_lo+(afs_hi*65535)
mb:close()
Modbus profiles examples - by AEK - 15.06.2017, 07:43
RE: Modbus profiles examples - by morak - 15.06.2017, 10:59
Modbus profiles examples - by ELO - 17.10.2017, 05:29
RE: Modbus profiles examples - by admin - 21.10.2017, 06:05
RE: Modbus profiles examples - by Gadjoken - 23.10.2017, 08:53
RE: Modbus profiles examples - by thientiti01 - 24.11.2017, 07:52
RE: Modbus profiles examples - by AEK - 27.11.2017, 09:18
RE: Modbus profiles examples - by thientiti01 - 27.11.2017, 10:25
RE: Modbus profiles examples - by jetsetter - 30.11.2017, 12:22
RE: Modbus profiles examples - by admin - 30.11.2017, 12:36
RE: Modbus profiles examples - by m.j.sorokin - 30.11.2017, 17:29
RE: Modbus profiles examples - by jmir - 04.12.2017, 14:19
RE: Modbus profiles examples - by FatMax - 05.12.2017, 22:53
RE: Modbus profiles examples - by admin - 06.12.2017, 07:01
RE: Modbus profiles examples - by FatMax - 08.12.2017, 09:06
RE: Modbus profiles examples - by Kaveckiy - 13.09.2018, 06:24
RE: Modbus profiles examples - by fiLLLip - 03.01.2019, 05:52
RE: Modbus profiles examples - by Daniel - 08.03.2019, 11:35
RE: Modbus profiles examples - by AlexLV - 10.03.2019, 15:12
RE: Modbus profiles examples - by admin - 11.03.2019, 07:35
RE: Modbus profiles examples - by AlexLV - 11.03.2019, 11:47
RE: Modbus profiles examples - by Rick - 19.10.2020, 09:53
RE: Modbus profiles examples - by Daniel - 19.10.2020, 09:59
RE: Modbus profiles examples - by Rick - 19.10.2020, 10:16
RE: Modbus profiles examples - by stavros - 29.10.2020, 14:13
RE: Modbus profiles examples - by admin - 29.10.2020, 14:25
RE: Modbus profiles examples - by stavros - 30.10.2020, 10:38
RE: Modbus profiles examples - by stemic01 - 04.11.2020, 20:56
RE: Modbus profiles examples - by AnLi_HOUSE - 11.11.2020, 18:33
RE: Modbus profiles examples - by victor.back - 20.11.2020, 18:34
RE: Modbus profiles examples - by epps - 18.07.2021, 15:05
RE: Modbus profiles examples - by epps - 18.07.2021, 18:21
RE: Modbus profiles examples - by lasttrip - 06.08.2021, 06:14
RE: Modbus profiles examples - by admin - 06.08.2021, 08:14
RE: Modbus profiles examples - by edgars - 26.08.2021, 08:22
RE: Modbus profiles examples - by Daniel - 18.10.2021, 13:47
RE: Modbus profiles examples - by tthamm - 08.01.2022, 07:31
RE: Modbus profiles examples - by admin - 10.01.2022, 08:07
RE: Modbus profiles examples - by tthamm - 23.01.2022, 17:27
RE: Modbus profiles examples - by admin - 24.01.2022, 07:14
RE: Modbus profiles examples - by tthamm - 02.10.2022, 10:48
RE: Modbus profiles examples - by Dré - 04.10.2022, 15:09
RE: Modbus profiles examples - by gtsamis - 28.01.2022, 18:05
RE: Modbus profiles examples - by Daniel - 31.01.2022, 08:41
RE: Modbus profiles examples - by gtsamis - 31.01.2022, 08:48
RE: Modbus profiles examples - by Ian@GWTi - 21.03.2022, 11:10
RE: Modbus profiles examples - by jmir - 23.03.2022, 13:43
RE: Modbus profiles examples - by admin - 23.03.2022, 14:41
RE: Modbus profiles examples - by jmir - 23.03.2022, 15:05
RE: Modbus profiles examples - by khalil - 15.06.2022, 14:11
RE: Modbus profiles examples - by Daniel - 15.06.2022, 14:42
RE: Modbus profiles examples - by admin - 16.06.2022, 07:12
RE: Modbus profiles examples - by khalil - 16.06.2022, 13:59
RE: Modbus profiles examples - by Ian@GWTi - 22.07.2022, 14:27
RE: Modbus profiles examples - by admin - 26.07.2022, 06:23
RE: Modbus profiles examples - by Daniel - 03.10.2022, 07:54
RE: Modbus profiles examples - by tthamm - 03.10.2022, 18:04
RE: Modbus profiles examples - by Daniel - 04.10.2022, 07:39
Modbus profiles examples - by fabiorusco - 27.12.2022, 14:48
RE: Modbus profiles examples - by fabiorusco - 28.12.2022, 07:01
RE: Modbus profiles examples - by admin - 28.12.2022, 07:30
RE: Modbus profiles examples - by fabiorusco - 28.12.2022, 08:32
RE: Modbus profiles examples - by pritorianz - 10.03.2023, 10:12
RE: Modbus profiles examples - by provodkapro - 01.04.2025, 08:26
RE: Modbus profiles examples - by Daniel - 01.04.2025, 08:40
LG AWHP Modbus RTU Profile - by KoBra - 08.04.2023, 13:16
RE: Modbus profiles examples - by AEK - 25.09.2023, 19:11
RE: Modbus profiles examples - by fabiorusco - 30.09.2023, 09:57
RE: Modbus profiles examples - by tomnord - 30.09.2023, 15:25
NIBE S1155 Modbus profile - by merel - 25.01.2024, 09:46
RE: Modbus profiles examples - by Tuwat47 - 16.07.2024, 08:02
RE: Modbus profiles examples - by epps - 23.09.2024, 07:42
RE: Modbus profiles examples - by Novodk - 20.11.2024, 13:31
Huawey Modbus TCP json - by CristianAgata - 06.10.2024, 13:02
RE: Huawey Modbus TCP json - by CristianAgata - 05.01.2025, 10:42
RE: Huawey Modbus TCP json - by atomi23 - 09.01.2025, 16:19
RE: Huawey Modbus TCP json - by CristianAgata - 09.01.2025, 16:28
RE: Huawey Modbus TCP json - by atomi23 - 09.01.2025, 16:32
RE: Modbus profiles examples - by Tuwat47 - 25.10.2024, 06:48
RE: Modbus profiles examples - by admin - 21.11.2024, 13:37
RE: Modbus profiles examples - by Ranjeet - 22.05.2025, 20:05
RE: Modbus profiles examples - by Daniel - 13.01.2025, 08:52
RE: Modbus profiles examples - by AlexLV - 12.02.2025, 21:09
RE: Modbus profiles examples - by FatMax - 17.03.2025, 13:38
RE: Modbus profiles examples - by Ranjeet - 31.03.2025, 12:03
RE: Modbus profiles examples - by Daniel - 31.03.2025, 12:50
RE: Modbus profiles examples - by kgroenhoej - 06.04.2025, 15:09
RE: Modbus profiles examples - by nhemtman - 15.04.2025, 12:46
RE: Modbus profiles examples - by Daniel - 15.04.2025, 12:48
RE: Modbus profiles examples - by nhemtman - 28.04.2025, 05:48
RE: Modbus profiles examples - by Daniel - 28.04.2025, 07:20
RE: Modbus profiles examples - by admin - 28.04.2025, 12:12
RE: Modbus profiles examples - by admin - 23.05.2025, 06:28
RE: Modbus profiles examples - by ALEJANDRO - 25.02.2026, 15:57
RE: Modbus profiles examples - by Daniel - 25.02.2026, 16:00
RE: Modbus profiles examples - by ALEJANDRO - 26.02.2026, 07:17
RE: Modbus profiles examples - by AEK - 26.02.2026, 07:35
RE: Modbus profiles examples - by ALEJANDRO - 04.03.2026, 15:40
RE: Modbus profiles examples - by ALEJANDRO - 15.04.2026, 11:17
RE: Modbus profiles examples - by admin - 15.04.2026, 11:24
RE: Modbus profiles examples - by ALEJANDRO - 15.04.2026, 12:30
