Irrigation program
#27
You don't need an extra script for this. In "Last instance only" mode all previous script instances are stopped once new value arrives.
Your script should be modified to turn off all outputs when false is received. This is needed because when the script is running it's mostly sleeping with one output turned on.
value = event.getvalue() function dosleep(obj)   local timer = grp.getvalue(obj)   timer = tonumber(timer)   if timer then     if timer < mintimer then       timer = mintimer     elseif timer > maxtimer then       timer = maxtimer     end     os.sleep(timer * 60) -- minutes -> seconds   end end mintimer = 0.1 -- minimum timer value in minutes maxtimer = 60 -- maximum timer value in minutes objects = {   {     output = '5/1/1',     timer = '5/3/1',     enable = '5/4/1',   },   {     output = '5/1/2',     timer = '5/3/2',     enable = '5/4/2',   },   {     output = '5/1/3',     timer = '5/3/3',     enable = '5/4/3',   },   {     output = '5/1/4',     timer = '5/3/4',     enable = '5/4/4',   },   {     output = '5/1/5',     timer = '5/3/5',     enable = '5/4/5',   },   {     output = '5/1/6',     timer = '5/3/6',     enable = '5/4/6',   },   {     output = '5/1/7',     timer = '5/3/7',     enable = '5/4/7',   },   {     output = '5/1/8',     timer = '5/3/8',     enable = '5/4/8',   },   {     output = '5/1/9',     timer = '5/3/9',     enable = '5/4/9',   },   {     output = '5/1/10',     timer = '5/3/10',     enable = '5/4/10',   } } for _, item in ipairs(objects) do   if value == true then     if grp.getvalue(item.enable) then       grp.write(item.output, true)       dosleep(item.timer)       grp.write(item.output, false)     end   else     grp.checkwrite(item.output, false)   end end
Irrigation program - by Domoticatorino - 01.08.2016, 22:34
RE: Irrigation program - by Domoticatorino - 02.08.2016, 19:59
RE: Irrigation program - by admin - 03.08.2016, 06:19
RE: Irrigation program - by Domoticatorino - 18.10.2016, 11:46
RE: Irrigation program - by admin - 18.10.2016, 12:02
RE: Irrigation program - by Domoticatorino - 20.04.2018, 23:21
RE: Irrigation program - by admin - 25.04.2018, 06:21
RE: Irrigation program - by Udelae - 11.03.2019, 17:17
RE: Irrigation program - by admin - 12.03.2019, 07:35
RE: Irrigation program - by Udelae - 12.03.2019, 08:11
RE: Irrigation program - by admin - 12.03.2019, 08:30
RE: Irrigation program - by Udelae - 12.03.2019, 13:18
RE: Irrigation program - by CristianAgata - 30.06.2021, 14:36
RE: Irrigation program - by Udelae - 12.03.2019, 14:36
RE: Irrigation program - by DanielB - 21.03.2019, 11:22
RE: Irrigation program - by Daniel - 30.06.2021, 14:57
RE: Irrigation program - by CristianAgata - 30.06.2021, 16:12
RE: Irrigation program - by balatis - 12.05.2022, 11:47
RE: Irrigation program - by David - 24.10.2023, 08:29
RE: Irrigation program - by Daniel - 24.10.2023, 08:38
RE: Irrigation program - by David - 24.10.2023, 08:47
RE: Irrigation program - by admin - 24.10.2023, 08:50
RE: Irrigation program - by josep - 24.10.2023, 09:17
RE: Irrigation program - by admin - 24.10.2023, 09:18
RE: Irrigation program - by David - 24.10.2023, 09:39
RE: Irrigation program - by admin - 24.10.2023, 09:45
