Dali Light secuence
Hi Josep,
Try this in a resident script, interval time doesn't matter.
outputaddress = '1/1/1' -- byte object -- set step values value1 = 20 value2 = 40 value3 = 60 value4 = 80 value5 = 100 -- set init value value = value1 -- set delay delaytime = 10 -- loop always while true do  -- check if value 1 needs to be written  if value == value1 then    value = value2    grp.write(outputaddress, value1)  -- check if value 2 needs to be written  elseif value == value2 then    value = value3    grp.write(outputaddress, value2)  -- check if value 3 needs to be written  elseif value == value3 then    value = value4    grp.write(outputaddress, value3)  -- check if value 4 needs to be written  elseif value == value4 then    value = value5    grp.write(outputaddress, value4)  -- check if value 5 needs to be written  elseif value == value5 then    value = value1    grp.write(outputaddress, value5)  -- fallback when value not valid  else    value = value1  end  -- delay loop  os.sleep(delaytime) end
When changing one of the declared values you need to restart the script.
If you reboot LM the sequense starts automaticly again as long as your resident script is having the active state.
Dali Light secuence - by josep - 06.02.2017, 18:40
RE: Dali Light secuence - by Erwin van der Zwart - 06.02.2017, 19:10
RE: Dali Light secuence - by josep - 06.02.2017, 19:25
