Netatmo
#50
(23.11.2023, 14:35)stigen Wrote: Hi!
My netatmo script, the old one, doesnt work anymore because they changed there API etc..
I have tried diffrent things but it doesnt work....
Does anyone have a step by step and example script with main module and outdoor module example?
Very nice if there is also in the script examples of how too grp.write to objects on the Logimachine Smile
Thanx!
Hi stigen,
in the first step you need to setup a Netatmo Developer account: https://dev.netatmo.com
Then create a application inside Netatmo development area to get the relevant tokens.
Then generate a new user script, name it "netatmo" and add the token in the following script:
require 'ltn12' require 'socket.http' json = require("json") https = require 'ssl.https' socket.http.TIMEOUT = 5 netatmo_debug = true client_id = "XXX" client_secret = "xxx" refresh_token_org = "xxx" -- get this token from the netatmo dev page, generate first auth and refresh_token request_token_url = "https://api.netatmo.net/oauth2/token" request_url = "https://api.netatmo.net/api" response_body = { } if (netatmo_debug) then   log("netatmo start") end -- get auth token from refresh token -- https://github.com/akbooer/Netatmo/blob/master/L_Netatmo.lua#L430 function refresh_token()     refresh = storage.get('netatmo_refresh_1', refresh_token_org)     local request_body = "grant_type=refresh_token&client_id=" .. client_id .."&client_secret=" .. client_secret .. "&refresh_token=" .. refresh   local body, code, hdrs, stat = https.request   {     url = request_token_url;     method = "POST";     headers =     {       ["Content-Type"] = "application/x-www-form-urlencoded";       ["Content-Length"] = #request_body;     };     source = ltn12.source.string(request_body);     sink = ltn12.sink.table(response_body);   }   if (code ~= 200) then     if (netatmo_debug) then       log("netatmo auth error: "..tostring(code)..", "..tostring(body))     end     return   end   local response_decode = json.decode(table.concat(response_body))   local access_token = response_decode.access_token   if response_decode.refresh_token then         storage.set('netatmo_refresh_1', response_decode.refresh_token)   end   if (netatmo_debug) then     log(response_body)     log("netatmo token %s",access_token)   end   return "access_token=" .. access_token  end -- init if not init then   if (netatmo_debug) then       log("netatmo init")     end      request_body = refresh_token()   init = true end if not request_body and netatmo_debug then     log("netatmo token error") end function get_stationdata()   if not request_body then return end   --to limit to only one device : -- local request_body = "access_token=" .. access_token .. "&device_id=" .. device_id   --https://dev.netatmo.com/dev/resources/technical/reference/weatherstation/getstationsdata   local response_body = { }   local body, code, hdrs, stat = https.request   {     url = request_url..'/getstationsdata';     method = "POST";     headers =     {       ["Content-Type"] = "application/x-www-form-urlencoded";       ["Content-Length"] = #request_body;     };     source = ltn12.source.string(request_body);     sink = ltn12.sink.table(response_body);   }   if (code ~= 200) then     if (netatmo_debug) then       log("netatmo devicelist error: "..tostring(code)..", "..tostring(body)..", "..tostring(hdrs)..", "..tostring(stat))     end     return   end   local response_decode = json.decode(table.concat(response_body))   if (netatmo_debug) then         log(response_decode)         log(response_decode.body.devices[1].modules[4].dashboard_data)   end --write station data to KNX         grp.write("Netatmo_Main_CO2",response_decode.body.devices[1].dashboard_data.CO2)     grp.write("Netatmo_Main_Humidity",response_decode.body.devices[1].dashboard_data.Humidity)     grp.write("Netatmo_Main_Temp",response_decode.body.devices[1].dashboard_data.Temperature)         grp.write("Netatmo_Aussen_Temp",response_decode.body.devices[1].modules[1].dashboard_data.Temperature)     grp.write("Netatmo_Aussen_Humidity",response_decode.body.devices[1].modules[1].dashboard_data.Humidity)     grp.write("Netatmo_Aussen_Battery",response_decode.body.devices[1].modules[1].battery_percent)         grp.write("Netatmo_Bad_Temp",response_decode.body.devices[1].modules[2].dashboard_data.Temperature)     grp.write("Netatmo_Bad_Humidity",response_decode.body.devices[1].modules[2].dashboard_data.Humidity)     grp.write("Netatmo_Bad_Battery",response_decode.body.devices[1].modules[2].battery_percent)     grp.write("Netatmo_Bad_CO2",response_decode.body.devices[1].modules[2].dashboard_data.CO2)         grp.write("Netatmo_Küche_Temp",response_decode.body.devices[1].modules[3].dashboard_data.Temperature)     grp.write("Netatmo_Küche_Humidity",response_decode.body.devices[1].modules[3].dashboard_data.Humidity)     grp.write("Netatmo_Küche_Battery",response_decode.body.devices[1].modules[3].battery_percent)     grp.write("Netatmo_Küche_CO2",response_decode.body.devices[1].modules[3].dashboard_data.CO2)         grp.write("Netatmo_Rain",response_decode.body.devices[1].modules[4].dashboard_data.Rain)     grp.write("Netatmo_Rain_24h",response_decode.body.devices[1].modules[4].dashboard_data.sum_rain_24)     grp.write("Netatmo_Rain_1h",response_decode.body.devices[1].modules[4].dashboard_data.sum_rain_1)     grp.write("Netatmo_Rain_Battery",response_decode.body.devices[1].modules[4].battery_percent) end if (netatmo_debug) then   log("netatmo end") end
In the next step you generate scheduled script (*/5****) and add the following code:
require('user.netatmo') get_stationdata()
Run the scheduled script and looking inside the log which module is the right category (outdoor, rain, wind etc.) and adjust the second number ...body.devices[1].modules[4]... .Furthermore change the object name to your KNX group address name.
Now you are ready to go. I hope it helps.
Best Regards
Steffen
Netatmo - by Matt - 13.07.2015, 21:43
RE: Netatmo - by George - 16.08.2015, 10:59
RE: Netatmo - by gjniewenhuijse - 04.01.2016, 15:24
RE: Netatmo - by Matt - 04.01.2016, 21:10
RE: Netatmo - by gjniewenhuijse - 11.01.2016, 14:59
RE: Netatmo - by Matt - 11.01.2016, 20:38
RE: Netatmo - by gjniewenhuijse - 12.02.2016, 06:40
RE: Netatmo - by buuuudzik - 22.08.2016, 11:46
RE: Netatmo - by admin - 12.02.2016, 07:09
RE: Netatmo - by Matt - 12.02.2016, 07:37
RE: Netatmo - by gjniewenhuijse - 12.02.2016, 09:20
RE: Netatmo - by gjniewenhuijse - 23.02.2016, 07:05
RE: Netatmo - by buuuudzik - 11.05.2016, 12:02
RE: Netatmo - by admin - 11.05.2016, 12:38
RE: Netatmo - by buuuudzik - 11.05.2016, 13:59
RE: Netatmo - by Peter - 17.05.2016, 21:57
RE: Netatmo - by Matt - 18.05.2016, 10:27
RE: Netatmo - by admin - 24.08.2016, 11:25
RE: Netatmo - by buuuudzik - 24.08.2016, 13:16
RE: Netatmo - by gjniewenhuijse - 10.10.2017, 08:20
RE: Netatmo - by Slok - 15.10.2017, 06:53
RE: Netatmo - by Evens - 14.10.2018, 16:03
RE: Netatmo - by Matt - 20.10.2018, 20:09
RE: Netatmo - by Peter - 29.12.2018, 23:46
RE: Netatmo - by paalidar - 30.01.2019, 17:56
RE: Netatmo - by Matt - 30.01.2019, 20:11
RE: Netatmo - by paalidar - 30.01.2019, 20:15
RE: Netatmo - by Erwin van der Zwart - 30.01.2019, 21:27
RE: Netatmo - by victor.back - 26.09.2020, 10:58
RE: Netatmo - by pioneersteffen - 14.09.2021, 19:48
RE: Netatmo - by Daniel - 15.09.2021, 07:35
RE: Netatmo - by pioneersteffen - 15.09.2021, 11:00
RE: Netatmo - by stemic01 - 10.02.2022, 20:32
RE: Netatmo - by Erwin van der Zwart - 11.02.2022, 00:22
RE: Netatmo - by stemic01 - 11.02.2022, 12:08
RE: Netatmo - by iridium - 13.07.2023, 09:53
RE: Netatmo - by gjniewenhuijse - 13.07.2023, 13:41
RE: Netatmo - by admin - 14.07.2023, 08:46
RE: Netatmo - by gjniewenhuijse - 14.07.2023, 11:52
RE: Netatmo - by gjniewenhuijse - 17.07.2023, 13:40
RE: Netatmo - by iridium - 18.07.2023, 07:26
RE: Netatmo - by stemic01 - 20.07.2023, 08:28
RE: Netatmo - by gjniewenhuijse - 21.07.2023, 06:44
RE: Netatmo - by stemic01 - 03.08.2023, 20:45
RE: Netatmo - by Daniel - 04.08.2023, 07:30
RE: Netatmo - by stemic01 - 04.08.2023, 08:35
RE: Netatmo - by Daniel - 04.08.2023, 09:05
RE: Netatmo - by MLa - 04.08.2023, 10:34
RE: Netatmo - by stigen - 23.11.2023, 14:35
RE: Netatmo - by pioneersteffen - 23.12.2023, 14:13
RE: Netatmo - by MLa - 19.07.2024, 07:59
RE: Netatmo - by MaLe - 14.10.2024, 11:41
RE: Netatmo - by gjniewenhuijse - 07.11.2024, 09:28
RE: Netatmo - by Daniel - 07.11.2024, 09:31
RE: Netatmo - by gjniewenhuijse - 08.11.2024, 14:21
RE: Netatmo - by iridium - 03.12.2024, 17:47
RE: Netatmo - by gjniewenhuijse - 04.12.2024, 12:42
RE: Netatmo - by iridium - 12.12.2024, 15:35
RE: Netatmo - by stemic01 - 01.04.2025, 12:24
RE: Netatmo - by Igor - 15.05.2025, 13:26
