Automatic export all logs and send by mail
#23
(05.10.2023, 06:52)admin Wrote: See this example: https://openrb.com/example-export-last-h...-from-lm2/
It has both local file and remote FTP options.
Hello Admin,
I have applied the solution from the example on the link, although unfortunately I just noticed that not all fields are included on the csv file. I would like to export all data that can be seen on the object logs utility. For the moment only timestamp, address, name and value is included in the csv export...
I am using the following script:
   --ftp file    ftpfile = string.format('/home/ftp/%s.csv', os.date('%Y-%m-%d_%H-%M'))    -- get past 12 hours data (43200 seconds)    logtime = os.time() - 12 * 60 * 60          -- list of objects by id     objects = {}          -- objects with logging enabled     query = 'SELECT address, datatype, name FROM objects WHERE disablelog=0'     for _, object in ipairs(db:getall(query)) do       objects[ tonumber(object.address) ] = {         datatype = tonumber(object.datatype),         name = tostring(object.name or ''),       }     end          -- csv buffer     buffer = { '"date","address","name","value"' }          -- get object logs     query = 'SELECT src, address, datahex, logtime, eventtype FROM objectlog WHERE logtime >= ? ORDER BY id DESC'     for _, row in ipairs(db:getall(query, logtime)) do       object = objects[ tonumber(row.address) ]            -- found matching object and event type is group write       if object and row.eventtype == 'write' then         datatype = object.datatype              -- check that object datatype is set         if datatype then           -- decode data           data = knxdatatype.decode(row.datahex, datatype)                -- remove null chars from char/string datatype           if datatype == dt.char or datatype == dt.string then             data = data:gsub('%z+', '')           -- date to DD.MM.YYYY           elseif datatype == dt.date then             data = string.format('%.2d.%.2d.%.2d', data.day, data.month, data.year)           -- time to HH:MM:SS           elseif datatype == dt.time then             data = string.format('%.2d:%.2d:%.2d', data.hour, data.minute, data.second)           end         else           data = ''         end              -- format csv row         logdate = os.date('%Y.%m.%d %H:%M:%S', row.logtime)         csv = string.format('%q,%q,%q,%q', logdate, knxlib.decodega(row.address), object.name, tostring(data))              -- add to buffer         table.insert(buffer, csv)       end     end              -- upload to ftp only when there's data in buffer     if #buffer > 1 then       data = table.concat(buffer, '\r\n')       io.writefile(ftpfile, data)     end
How can this be modified to include the type (read/write) and source address fields?
Kind Regards,
RE: Automatic export all logs and send by mail - by manos@dynamitec - 16.01.2024, 11:59
