30.01.2024, 10:12
2024.04 RC3 https://forum.logicmachine.net/showthread.php?tid=5393
Notable changes
- KNX data secure support
- Basic IPv6 support
- 802.1X EAP-TLS support
- Improved look & feel of the main configurator UI
- Reworked login procedure without the use of Basic authentication
- Automatic filter table creation for KNX project import
- "Update existing objects" option for KNX project import
- DALI2 support added to CANx-DALI
- Support for new LM Starter app
Known issues
- Homekit application must be updated to the latest version via LM app store after the firmware upgrade.
New LM Home application
More info here: https://forum.logicmachine.net/showthread.php?tid=5220
You can find the hardware model in the "Upgrade firmware" window:
![[Image: attachment.php?aid=1740]](https://forum.logicmachine.net/attachment.php?aid=1740)
KNX Data Secure
A complete guide on KNX data secure usage will be published later.
In short you need to add a dummy KNX secure device into your ETS project. We don't provide our own dummy device at the moment, you can use any secure dummy device from other manufacturers.
This dummy device must have the same physical address as LM. All relevant secure groups must be added to the dummy device.
Notable changes
Known issues
KNX Data Secure
