dt.uint64
You can use an event script attached to a tag if input/output group addresses follow the same structure.
id = event.dst:split('/')[3] addr = '10/0/' .. id val = event.getvalue() / 1000 ffi = require('ffi') dst = ffi.new('unsigned char[8]') src = ffi.new('double[1]') src[ 0 ] = tonumber(val) or 0 ffi.copy(dst, src, 8) res = ffi.string(dst, 8) grp.write(addr, res, dt.raw)
dt.uint64 - by DGrandes - 08.07.2022, 09:30
RE: dt.uint64 - by admin - 08.07.2022, 09:35
RE: dt.uint64 - by DGrandes - 08.07.2022, 10:04
RE: dt.uint64 - by admin - 08.07.2022, 10:52
RE: dt.uint64 - by DGrandes - 08.07.2022, 11:13
RE: dt.uint64 - by manos@dynamitec - 19.02.2024, 23:40
RE: dt.uint64 - by admin - 20.02.2024, 06:30
RE: dt.uint64 - by manos@dynamitec - 20.02.2024, 08:33
RE: dt.uint64 - by admin - 20.02.2024, 09:01
RE: dt.uint64 - by manos@dynamitec - 20.02.2024, 09:38
RE: dt.uint64 - by admin - 20.02.2024, 09:46
RE: dt.uint64 - by manos@dynamitec - 20.02.2024, 10:08
RE: dt.uint64 - by admin - 20.02.2024, 10:13
RE: dt.uint64 - by manos@dynamitec - 20.02.2024, 11:01
