dt.uint64
(20.02.2024, 09:46)admin Wrote: You can use an event script attached to a tag if input/output group addresses follow the same structure.
id = event.dst:split('/')[3] addr = '10/0/' .. id val = event.getvalue() / 1000 ffi = require('ffi') dst = ffi.new('unsigned char[8]') src = ffi.new('double[1]') src[ 0 ] = tonumber(val) or 0 ffi.copy(dst, src, 8) res = ffi.string(dst, 8) grp.write(addr, res, dt.raw)
Although this is a very clean, quick and smart solution, unfortunately the standard energy objects are having a different pattern than just changing the last part. The raw data objects will be created according to a table I would say in the range of 30/3/1->58 or something. I have to use 30 because the visu server cannot receive virtual addresses 32+/*/*.
I have attached all 58 objects to be processed. This is the reason why I would prefer in my application to use a table.
.pdf   Energy GAs.pdf (Size: 75.99 KB / Downloads: 6)
dt.uint64 - by DGrandes - 08.07.2022, 09:30
RE: dt.uint64 - by admin - 08.07.2022, 09:35
RE: dt.uint64 - by DGrandes - 08.07.2022, 10:04
RE: dt.uint64 - by admin - 08.07.2022, 10:52
RE: dt.uint64 - by DGrandes - 08.07.2022, 11:13
RE: dt.uint64 - by manos@dynamitec - 19.02.2024, 23:40
RE: dt.uint64 - by admin - 20.02.2024, 06:30
RE: dt.uint64 - by manos@dynamitec - 20.02.2024, 08:33
RE: dt.uint64 - by admin - 20.02.2024, 09:01
RE: dt.uint64 - by manos@dynamitec - 20.02.2024, 09:38
RE: dt.uint64 - by admin - 20.02.2024, 09:46
RE: dt.uint64 - by manos@dynamitec - 20.02.2024, 10:08
RE: dt.uint64 - by admin - 20.02.2024, 10:13
RE: dt.uint64 - by manos@dynamitec - 20.02.2024, 11:01
