grp.create() value_custom
(16.05.2022, 07:43)admin Wrote: This field is called enums in grp.create. It should either be a Lua table or a string containing a JSON object.
Hi again,
It works for objects accepting custom values. However the following code causes temperature to be read as (22) instead of 22.15
grp.create({     datatype = 9001,     address = '3/2/56',     name = 'Temperature',     enums = {},     comment = '',     forcename =true   })
So, I also tried
enums = nil
which works, but point is, if I had once set
enums = {},
then
enums = nil
cannot fix object read value until I delete it and recreate it.
I addition when I log same object when set right I see an empty string for enum key.
Can you please make more clear all the above.
Thanks in advance.
grp.create() value_custom - by emme - 15.05.2022, 13:25
RE: grp.create() value_custom - by admin - 16.05.2022, 07:43
RE: grp.create() value_custom - by p_xatzi - 29.02.2024, 11:42
RE: grp.create() value_custom - by admin - 29.02.2024, 12:04
