05.03.2024, 12:59
You can place the code inside a user library and disable "Keep source" and keep "Auto load library" disabled. Then in your code you can simply call require('user.backup')
The password can still be recovered from the backup but it will be harder since the library file will be in Lua bytecode format.
You should also limit the user rights on FTP by providing a write-only access. Another thing to keep in mind is that FTP is plain text protocol without any encryption by default. See this for more info on how to enable encryption if the web server supports it: https://forum.logicmachine.net/showthrea...50#pid5850 (package update is not needed)
