Help example on simple light controll, lux
(14.03.2024, 09:26)admin Wrote: You can use grp.find() and updatetime field to check when the last telegram was sent to this specific object. Then use os.time() to calculate the delta.
Alternative solution is to use a scheduled script that runs every X minutes.
Hi admin that will not work for me as the updatetime of the object is changing all the time.
lux = grp.getvalue('1/0/3') azimut = grp.getvalue('5/5/2') alarm = grp.getvalue('4/0/1') hysterese = 10 if alarm == false then     if lux > 700 then       if azimut > 95 and azimut < 150 then         grp.write('2/3/1', 100)         grp.write('2/3/2', 0)         grp.write('2/3/6', 0)       elseif azimut > 180 and azimut < 230 then         grp.write('2/3/1', 0)         grp.write('2/3/2', 100)         grp.write('2/3/6', 0)       elseif azimut > 230 and azimut < 280 then         grp.write('2/3/1', 0)         grp.write('2/3/2', 0)         grp.write('2/3/6', 100)       else         grp.write('2/3/1', 0)         grp.write('2/3/2', 0)         grp.write('2/3/6', 0)       end     elseif lux < 500 then           object = grp.find('1/0/3')           time = object.updatetime -- time will change every time the object is updated       grp.write('2/3/1', 0)       grp.write('2/3/2', 0)       grp.write('2/3/6', 0)     end end
RE: Help example on simple light controll, lux - by Joep - 14.03.2024, 09:47
