SE SpaceLynk Presence Simulation - Trigger start by Object
When you create a recordening, or edit a exiting one you can add an binary object, when the object is false it records, when it is true it is playing back the recording...
If you don't have an object attached you can do it manual via the stop/pauze icon on the recording container, this icon disapears when you attached the recording to an object..
Keep in mind how the recordings are setup / working by default, when recorded at monday at 10:00, it will play the recording on monday at that moment when you set it in play mode in that week...
Use custom recording if you want to use recordings from other recordings to mix and match..
RE: SE SpaceLynk Presence Simulation - Trigger start by Object - by Erwin van der Zwart - 14.03.2024, 12:15
