SE SpaceLynk Presence Simulation - Trigger start by Object
Thanks for your hints. I got it working now:
When you create a new recording, you must have to create a GA via APP (*/*/* or a new GA) - See Screenshot. The App will then create a new GA. The GA created can then be used to start recordings (0) or to switch to play mode (1).
What does NOT work for me is to create a recording without a new GA and then subsequently assign an already existing GA. In this case, the recording woll not be controlled via GA.
For me, control via GA is only possible if a separate, new GA is created by the APP, same time when the recording is created.
Perhaps this information will help someone who is experiencing the same problem.
RE: SE SpaceLynk Presence Simulation - Trigger start by Object - by ralwet - 14.03.2024, 22:34
