LS: after Update FW 3.0.0 values in backets
Today I did an SL update form 2.8.0 to 3.0.0.
The update went through without any problems. However, there is now a problem. Some GA values are now displayed in brackets (see screenshot).
These are then not displayed at all in the visualization. However, not all objects are affected. It seems that only those objects are affected which I once created via script, like this:
-- ************** RUN THIS SCRIPT ONCE TO CREATE YOUR OBJECTS **************-- --**************************************************************************-- --*** Address setup for Thermokon SAB05 - created by Erwin van der Zwart ****-- --************ For HL from FW 1.5 and SL from FW 1.2 with NGINX ************-- -- ENOCEAN EEP for Micropelt iTVR ******************************************-- -- R-ORG: 0xA5 *************************************************************-- -- FUNC:  0x20 *************************************************************-- -- TYPE:  0x01 *************************************************************-- --*************************** Start of parameters **************************-- -- Version 1.1 *************************************************************-- -- Set KNX main group maingroup = 6 -- Set KNX middle group middlegroup = 2 -- Set number of valves (max 19 -> 19 x 13 objects = 247 = max in 1 group range) numberofvalves = 1 -- Name des Ventils NameOfValve = 'Kino' --**************************************************************************-- --**************************** End of parameters ***************************-- --**************************************************************************-- --****************** DON'T CHANGE ANYTHING UNDER THIS LINE *****************-- --**************************************************************************-- --Check to avoid creating more then max number of valves */*/247 ( = 11 x 23 objects in 1 maingroup) if numberofvalves > 0 and numberofvalves <= 19 then   --Check to avoid address 0/0/0   if maingroup == 0 then       endgroup = 1   else         endgroup = 0   end   --Loop for creating number of valves   for i = 1, numberofvalves, 1 do     --Prefixed object types, enmums and min-max     objectcreatemapping = {       [1] = {         nm = 'Incomming Enocean Telegram',         dttp = dt.uint32,         nts = '',         nms = {},         vsprms = {},       },       [2] = {         nm = 'Incomming Enocean Status',          dttp = dt.uint8,         nts = '',         nms = {},         vsprms = {},       },       [3] = {         nm = 'Outgoing Enocean Telegram',          dttp = dt.uint32,         nts = '',          nms = {},         vsprms = {},       },       [4] = {         nm = 'Outgoing Enocean Status',          dttp = dt.uint8,         nts = '',         nms = {},         vsprms = {},       },       [5] = {         nm = 'Valve Position',          dttp = dt.scale,         nts = ' %',         nms = {},         vsprms = {},       },       [6] = {         nm = 'Valve Position Feedback',         dttp = dt.scale,         nts = ' %',          nms = {},         vsprms = {},       },       [7] = {         nm = 'Room Temperature',         dttp= dt.float16,         nts = ' °C',          nms = {},         vsprms = {},       },       [8] = {         nm = 'Summer Mode',         dttp= dt.bool,         nts = ' °C',         nms = {           [0] = "Wakeup cycle every 10 minutes",           [1] = "Wakeup cycle every 8 hours",           ["default"] = "",         },         vsprms = {},       },             [9] = {         nm = 'Active Harvesting',         dttp= dt.bool,         nts = ' °C',         nms = {           [0] = "Cold - Not loading",           [1] = "Hot - Loading",           ["default"] = "",         },         vsprms = {},       },       [10] = {         nm = 'Energy Level',         dttp= dt.bool,         nts = ' °C',         nms = {           [0] = "Empthy - Not sufficient loaded",           [1] = "Full - Sufficient loaded",           ["default"] = "",         },         vsprms = {},       },       [11] = {         nm = 'Internal Temperature of iTVR',         dttp= dt.float16,         nts = ' °C',          nms = {},         vsprms = {},       },       [12] = {         nm = 'Telegram Type',         dttp= dt.bool,         nts = '',          nms = {           [0] = "Teach-in telegram",           [1] = "Data telegram",           ["default"] = "",         },         vsprms = {},       },       [13] = {         nm = 'RAW Telegram Data',         dttp= dt.string,         nts = '',         nms = {},       },       vsprms = {},       [14] = {         nm =  NameOfValve .. ' Zieltemperatur',         dttp= dt.float16,         nts = ' °C',          nms = {},         vsprms = {},       },     }         --Loop for creating all objects for each valve     for j = 1, #objectcreatemapping, 1 do       address = grp.create({           --name = 'Thermokon SAB05 Valve ' .. i .. ' - ' .. objectcreatemapping[j].nm,           name = 'Thermokon SAB05 ' .. NameOfValve .. ' - ' .. objectcreatemapping[j].nm,           address = maingroup .. '/' .. middlegroup .. '/' .. endgroup,           datatype = objectcreatemapping[j].dttp,           visparams = objectcreatemapping[j].vsprms,           enums = objectcreatemapping[j].nms,           units = objectcreatemapping[j].nts,           tags = {'EEP A5-20-01', 'Valve ' .. NameOfValve},           comment = 'Auto created by script',       })       endgroup = endgroup + 1     end   end end script.disable(_SCRIPTNAME)
does anyone know this problem?
LS: after Update FW 3.0.0 values in backets - by ralwet - 17.04.2024, 14:59
