19.04.2024, 08:16
(19.04.2024, 07:55)admin Wrote: 1. Check that the modem is detected when the system starts in System config > Status > System log.
2. Run this script and post what you get in Logs:
Code:tty1 = '/dev/ttyACM3' tty2 = '/dev/ttyUSB2' if io.exists(tty1) then tty = tty1 elseif io.exists(tty2) then tty = tty2 else log('port not found') return end port = require('serial').open(tty) if not port then log('cannot open port') return end function readstatus() local data, res, simok, network port:flush() port:write('AT+CSQ\r\n') data = port:read(1000, 1) if data then res = data:match('+CSQ: (%d+)') res = tonumber(res) if res then log('Signal: ' .. tostring(res)) else log('Signal: no response') end else log('Signal: no data from port') end port:flush() port:write('AT+CPIN?\r\n') data = port:read(1000, 1) or '' if data:find('CME ERROR') then log('SIM: not found') elseif data:find('+CPIN: READY') then log('SIM: OK') simok = true else log('SIM: unknown') end port:flush() port:write('AT+COPS?\r\n') data = port:read(1000, 1) if data then res = data:match('+COPS: %d+,%d+,"(.*)",%d+') if res then log('Network: ' .. tostring(res)) network = res else log('Network: no info') end else log('Network: no data from port') end return simok and network end for i = 1, 20 do if readstatus() then break end end
OK in the log i see error network no info and SIM not found signal 13, but in the phone the SIM works.
Why ?
