Copas - TCP status and Control
(20.05.2024, 07:24)admin Wrote: Please describe your task in more detail. Most likely this can be done without copas, just with normal sockets and correctly set timeout values.
Im using copas as the device being connecting to only accepts 1 TCP conenction on 1 port for send and recieve. local UDP server on the LM sends event driven messages via copas TCP conenction which also recieves and updates objects.
I'd like to periodically check the connection is still alive and update a status object.
The device uses the same port for commisisoning, so i want to add some buttons to a page to disconnect, connect or do a reconnect ( refresh the connection ). So when commisisoning is required we can disconnect, and then reconnect when commisioning is complete.
Copas - TCP status and Control - by Diggerz - 17.05.2024, 22:08
RE: Copas - TCP status and Control - by admin - 20.05.2024, 07:24
RE: Copas - TCP status and Control - by Diggerz - 20.05.2024, 07:44
RE: Copas - TCP status and Control - by admin - 15.07.2024, 06:30
RE: Copas - TCP status and Control - by admin - 15.07.2024, 10:57
