mqtt with logic machine
"not authorized" error means wrong username and/or password.
This works for me:
broker = 'mqtt.intingy.com' port = 1883 username = 'entelechy_gateway' password = 'wr6NOng8HzFC2KpB5cPoxXXgCSYBHXbGgRG9b3R39ok' topic = 'entelechy/' payload = 'mqtt_connection_test' mqtt = require('mosquitto') client = mqtt.new() client.ON_CONNECT = function(status, rc, msg)   if status then     log('mqtt connected')     client:publish(topic, tostring(payload))   else     log('mqtt connect failed ' .. tostring(msg))     client:disconnect()   end end client.ON_PUBLISH = function()   log('publish ok')   client:disconnect() end client:login_set(username, password) status, rc, msg = client:connect(broker, port) if status then   client:loop_forever() else   log('connect failed: ' .. tostring(msg)) end
mqtt with logic machine - by abby - 01.05.2024, 13:36
RE: mqtt with logic machine - by admin - 01.05.2024, 13:57
RE: mqtt with logic machine - by abby - 23.05.2024, 14:15
RE: mqtt with logic machine - by admin - 23.05.2024, 14:39
RE: mqtt with logic machine - by abby - 24.05.2024, 08:58
RE: mqtt with logic machine - by admin - 24.05.2024, 09:01
RE: mqtt with logic machine - by abby - 24.05.2024, 09:37
RE: mqtt with logic machine - by admin - 24.05.2024, 09:41
RE: mqtt with logic machine - by abby - 24.05.2024, 13:14
RE: mqtt with logic machine - by admin - 24.05.2024, 13:29
RE: mqtt with logic machine - by abby - 27.05.2024, 09:35
RE: mqtt with logic machine - by admin - 27.05.2024, 09:41
RE: mqtt with logic machine - by abby - 27.05.2024, 09:57
RE: mqtt with logic machine - by admin - 27.05.2024, 09:59
RE: mqtt with logic machine - by abby - 27.05.2024, 10:12
RE: mqtt with logic machine - by admin - 27.05.2024, 10:28
RE: mqtt with logic machine - by abby - 27.05.2024, 11:21
RE: mqtt with logic machine - by admin - 27.05.2024, 11:51
RE: mqtt with logic machine - by abby - 27.05.2024, 12:39
RE: mqtt with logic machine - by admin - 28.05.2024, 08:28
RE: mqtt with logic machine - by abby - 05.06.2024, 12:41
RE: mqtt with logic machine - by admin - 05.06.2024, 12:45
RE: mqtt with logic machine - by abby - 05.06.2024, 12:56
RE: mqtt with logic machine - by admin - 05.06.2024, 13:19
RE: mqtt with logic machine - by abby - 05.06.2024, 14:08
RE: mqtt with logic machine - by admin - 05.06.2024, 14:17
RE: mqtt with logic machine - by abby - 17.06.2024, 06:52
