mqtt with logic machine
still showing the same error
if not broker then   broker = '192.168.29.48'   function multiply(mult)     return function(value)       local num = tonumber(value)       if num then         return num * mult       else         return value       end     end   end   -- topic to object map   mqtt_to_object = {     ['in/topic1'] = '32/1/1',     ['in/topic2'] = '32/1/2',   }   -- optional topic value conversion function   mqtt_to_object_conv = {     ['in/topic1'] = multiply(100),     ['in/topic2'] = multiply(0.01),   }   -- object to topic map   object_to_mqtt = {     ['1/1/1'] = 'out/topic1',     ['1/1/2'] = 'out/topic2',   }   datatypes = {}   grp.sender = 'mq'   require('socket')   for addr, _ in pairs(object_to_mqtt) do     local obj = grp.find(addr)     if obj then       datatypes[ addr ] = obj.datatype     end   end   mclient = require('mosquitto').new()     mclient:login_set('entelechy_gateway', 'wr6NOng8HzFC2KpB5cPoxXXgCSYBHXbGgRG9b3R39ok')   mclient.ON_CONNECT = function(res, ...)     log('mqtt connect status', res, ...)     if res then       for topic, _ in pairs(mqtt_to_object) do         mclient:subscribe(topic)       end     else       mclient:disconnect()     end   end   mclient.ON_MESSAGE = function(mid, topic, payload)     local addr = mqtt_to_object[ topic ]     if addr then       local fn = mqtt_to_object_conv[ topic ]       if fn then         payload = fn(payload)       end       grp.write(addr, payload)     end   end   mclient.ON_DISCONNECT = function(...)     log('mqtt disconnect', ...)     mclientfd = nil   end   function mconnect()     local fd     mclient:connect(broker)     fd = mclient:socket()     -- fd ref is valid     if fd then       mclientfd = fd     end   end   mconnect()   function publishvalue(event)     -- message from us or client is not connected     if event.sender == 'mq' or not mclientfd then       return     end     local addr = event.dst     local dpt = datatypes[ addr ]     local topic = object_to_mqtt[ addr ]     -- unknown object     if not dpt or not topic then       return     end     local value = busdatatype.decode(event.datahex, dpt)     if value ~= nil then       if type(value) == 'boolean' then         value = value and 1 or 0       end       mclient:publish(topic, tostring(value))     end   end   lbclient = require('localbus').new(1)   lbclient:sethandler('groupwrite', publishvalue)   lbclientfd = socket.fdmaskset(lbclient:getfd(), 'r')   -- run timer every 5 seconds   timer = require('timerfd').new(5)   timerfd = socket.fdmaskset(timer:getfd(), 'r') end -- mqtt connected if mclientfd then   mclientfdset = socket.fdmaskset(mclientfd, mclient:want_write() and 'rw' or 'r')   res, lbclientstat, timerstat, mclientstat =       socket.selectfds(10, lbclientfd, timerfd, mclientfdset) -- mqtt not connected else   res, lbclientstat, timerstat =     socket.selectfds(10, lbclientfd, timerfd) end if mclientfd and mclientstat then   if socket.fdmaskread(mclientstat) then     mclient:loop_read()   end   if socket.fdmaskwrite(mclientstat) then     mclient:loop_write()   end end if lbclientstat then   lbclient:step() end if timerstat then   -- clear armed timer   timer:read()   if mclientfd then     mclient:loop_misc()   else     mconnect()   end end
mqtt with logic machine - by abby - 01.05.2024, 13:36
RE: mqtt with logic machine - by admin - 01.05.2024, 13:57
RE: mqtt with logic machine - by abby - 23.05.2024, 14:15
RE: mqtt with logic machine - by admin - 23.05.2024, 14:39
RE: mqtt with logic machine - by abby - 24.05.2024, 08:58
RE: mqtt with logic machine - by admin - 24.05.2024, 09:01
RE: mqtt with logic machine - by abby - 24.05.2024, 09:37
RE: mqtt with logic machine - by admin - 24.05.2024, 09:41
RE: mqtt with logic machine - by abby - 24.05.2024, 13:14
RE: mqtt with logic machine - by admin - 24.05.2024, 13:29
RE: mqtt with logic machine - by abby - 27.05.2024, 09:35
RE: mqtt with logic machine - by admin - 27.05.2024, 09:41
RE: mqtt with logic machine - by abby - 27.05.2024, 09:57
RE: mqtt with logic machine - by admin - 27.05.2024, 09:59
RE: mqtt with logic machine - by abby - 27.05.2024, 10:12
RE: mqtt with logic machine - by admin - 27.05.2024, 10:28
RE: mqtt with logic machine - by abby - 27.05.2024, 11:21
RE: mqtt with logic machine - by admin - 27.05.2024, 11:51
RE: mqtt with logic machine - by abby - 27.05.2024, 12:39
RE: mqtt with logic machine - by admin - 28.05.2024, 08:28
RE: mqtt with logic machine - by abby - 05.06.2024, 12:41
RE: mqtt with logic machine - by admin - 05.06.2024, 12:45
RE: mqtt with logic machine - by abby - 05.06.2024, 12:56
RE: mqtt with logic machine - by admin - 05.06.2024, 13:19
RE: mqtt with logic machine - by abby - 05.06.2024, 14:08
RE: mqtt with logic machine - by admin - 05.06.2024, 14:17
RE: mqtt with logic machine - by abby - 17.06.2024, 06:52
