mqtt with logic machine
#20
You only need to modify this table:
mqtt_to_object = {   ['in/topic1'] = '32/1/1',   ['in/topic2'] = '32/1/2', }
In this example data published to topic named in/topic1 is sent to group address 32/1/1
So you need to adjust the topic name and group address as needed. Then in LM UI create a trend log that is attached to the same group address.
Depending on the trend log settings it might take up to several hours for the chart to start displaying values.
mqtt with logic machine - by abby - 01.05.2024, 13:36
RE: mqtt with logic machine - by admin - 01.05.2024, 13:57
RE: mqtt with logic machine - by abby - 23.05.2024, 14:15
RE: mqtt with logic machine - by admin - 23.05.2024, 14:39
RE: mqtt with logic machine - by abby - 24.05.2024, 08:58
RE: mqtt with logic machine - by admin - 24.05.2024, 09:01
RE: mqtt with logic machine - by abby - 24.05.2024, 09:37
RE: mqtt with logic machine - by admin - 24.05.2024, 09:41
RE: mqtt with logic machine - by abby - 24.05.2024, 13:14
RE: mqtt with logic machine - by admin - 24.05.2024, 13:29
RE: mqtt with logic machine - by abby - 27.05.2024, 09:35
RE: mqtt with logic machine - by admin - 27.05.2024, 09:41
RE: mqtt with logic machine - by abby - 27.05.2024, 09:57
RE: mqtt with logic machine - by admin - 27.05.2024, 09:59
RE: mqtt with logic machine - by abby - 27.05.2024, 10:12
RE: mqtt with logic machine - by admin - 27.05.2024, 10:28
RE: mqtt with logic machine - by abby - 27.05.2024, 11:21
RE: mqtt with logic machine - by admin - 27.05.2024, 11:51
RE: mqtt with logic machine - by abby - 27.05.2024, 12:39
RE: mqtt with logic machine - by admin - 28.05.2024, 08:28
RE: mqtt with logic machine - by abby - 05.06.2024, 12:41
RE: mqtt with logic machine - by admin - 05.06.2024, 12:45
RE: mqtt with logic machine - by abby - 05.06.2024, 12:56
RE: mqtt with logic machine - by admin - 05.06.2024, 13:19
RE: mqtt with logic machine - by abby - 05.06.2024, 14:08
RE: mqtt with logic machine - by admin - 05.06.2024, 14:17
RE: mqtt with logic machine - by abby - 17.06.2024, 06:52
