/tmp partition full, should I worry?
I have noticed that on some of my LM's, the partition mounted on /tmp is full, for instance, in the "Partitions" dialog:
tmpfs 124.5M 124.0M (100%) 528.0K /tmp
Is this normal? Or should I worry about it? How can this be solved?
Furthermore, I executed the following Lua code to inspect which are the files inside /tmp and which are the ones that take up the most space in the partition:
local command = "find /tmp -type f -exec ls -l {} + | awk '{print $5, $9}' | sort -nr 2>&1" local result = io.popen(command):read("*a"):trim() log(result)
Here are the first lines of the result:
8670716 /tmp/lua_MgIPLL 8670257 /tmp/lua_NNPkKE 8670122 /tmp/lua_LjNhiA 8669658 /tmp/lua_OoIiJP 8669051 /tmp/lua_npLNGJ 8668460 /tmp/lua_EKcfhn 8668256 /tmp/lua_oApkAo 8665087 /tmp/lua_iNFJGL 8661846 /tmp/lua_naliMb 8661725 /tmp/lua_cAGiJK 8661703 /tmp/lua_IOjJIN 8661114 /tmp/lua_hokPHE 8660365 /tmp/lua_mAkAlP 4874240 /tmp/scada.db 1691648 /tmp/log/debug.log.2 1179397 /tmp/log/debug.log 34417 /tmp/scripting/210.lua 32810 /tmp/scripting/358.lua 24529 /tmp/scripting/340.lua 23334 /tmp/scripting/320.lua 18756 /tmp/lp/2b36717769101395fb60f21c4e1acd71/1686556848.lua
As you can see with the numbers (that are file sizes in bytes), the 14 most heavy files (lua_xxxxx where xxxxxx seems to be a random sequence of 6 letters) each take up ~8'668'000 bytes which is 8.25 MB.
8.25 MB times 14 is about 115 MB, so these 14 files account for about 115 MB of the 124 MB used space in the /tmp partition, that is to say, the vast majority of it.
So, what are these files? Why do they take up so much space in this partition, and is this a problem? If it is, what can be done to address the situation?
/tmp partition full, should I worry? - by rbourgeon - 29.05.2024, 14:07
