Lutron send command
Modify lutron_login() in the user library to log the data that is sent to LM.
function lutron_login()   local tcp, tcp_err = lutron_connect()   if not tcp then     return nil, tcp_err   end   local res, err   res, err = tcp:receive(7)   log(res, err)      tcp:send(user..'\r\n')      res, err = tcp:receive(10)   log(res, err)   tcp:send(password..'\r\n')      res, err = tcp:receive(9)   log(res, err)   if res == nil or res == 'bad login' then     tcp:close()     return nil, res   end   return tcp end
Add log(lutron_receive(tcp)) at the end of your script to check the reply.
Lutron send command - by Hadeel - 31.05.2024, 08:17
RE: Lutron send command - by admin - 31.05.2024, 09:21
RE: Lutron send command - by Hadeel - 05.06.2024, 04:08
RE: Lutron send command - by Andrea Becagli - 16.09.2024, 11:43
RE: Lutron send command - by admin - 16.09.2024, 11:57
RE: Lutron send command - by Andrea Becagli - 16.09.2024, 12:28
RE: Lutron send command - by admin - 16.09.2024, 12:31
RE: Lutron send command - by Andrea Becagli - 16.09.2024, 12:35
