openDTU - JSON - http post - "no values found"
This is something which I already tried. In this case I get the following log:
* arg: 1   * string: {"type":"warning","message":"No values found!","code":1002} * arg: 2   * number: 200 * arg: 3   * table:    ["content-length"]     * string: 59    ["accept-ranges"]     * string: none    ["content-type"]     * string: application/json    ["connection"]     * string: close * arg: 4   * string: HTTP/1.1 200 OK
I log "body" as well and get the following result:
* string: {"limit_value":"10","limit_type":"1","serial":"000000000000"}
I don't understand why the serial is still in the thrid position. I changed the code and expect the serial to be on first position. Why does this not happen?
body = json.encode({       serial = '000000000000',     limit_type = '1',        limit_value = '10', })
For a common understandig - although it's not shown hier in the code, I use the correct serial and IP.
RE: openDTU - JSON - http post - "no values found" - by cgn - 10.06.2024, 14:51
