array of group addresses
Assign a common tag to the required objects then use this script:
value = 1 objects = grp.tag('my_tag_name') for _, obj in ipairs(objects) do   res = obj:checkwrite(value)   if res then     os.sleep(0.1)   end end
A better approach is to assign a common group address to all KNX devices because sending many telegrams at once can overflow the bus. The script above has a delay between each telegram to prevent this but it means that some devices will receive the value later.
array of group addresses - by almoisey - 18.07.2024, 05:16
RE: array of group addresses - by admin - 18.07.2024, 05:45
