Http Api command to Zennio Getface IP
#29
(08.08.2024, 09:18)admin Wrote: It does not work because the Authorization header is not sent with the request. Certain integrations expect a WWW-Authenticate to be sent by the server before sending the Authorization header.
Next firmware will have an option in Remote services settings to enable old behavior with the "WWW-Authenticate" header.
but it was working in SL 2.8 Version! did you change the authentication?
should I contact with Zennio in order to upgrade their http command authorization?
Best Regards,
RE: Http Api command to Zennio Getface IP - by khalil - 08.08.2024, 09:26
