Zigbee lights
There's no RGB in ZigBee. It uses XY color coordinates for setting the color. LM convert RGB to XY and brightness value to keep the behavior consistent with KNX. Converting XY back to RGB will produce a slightly different RGB value due to rounding errors. Status is not implemented because many lamps do not support reporting of XY color changes only brightness and on/off.
I don't see a point in copying control object value to status if the same can be achieved by using only a single control object.
Zigbee lights - by stianj - 02.09.2024, 13:01
RE: Zigbee lights - by Daniel - 02.09.2024, 13:28
RE: Zigbee lights - by stianj - 02.09.2024, 20:03
RE: Zigbee lights - by admin - 03.09.2024, 08:04
RE: Zigbee lights - by stianj - 03.09.2024, 12:51
RE: Zigbee lights - by admin - 03.09.2024, 12:57
