MQTT Broker Project with 2024 FW Problem
Try changing object value and the topic will appear in MQTT Explorer.
If you want to keep last topic values for other clients then you need to enable retain flag for messages. To do this replace last line in publishvalue:
mclient:publish(topic, tostring(value))
With this:
mclient:publish(topic, tostring(value), 0, true)
Note that LM MQTT broker does not have any persistence. If the broker is restarted then retained topics are lost until new value is published.
Additionally you can modify the script to publish all mapped values after a connection to broker is established. Replace mclient.ON_CONNECT with this:
  mclient.ON_CONNECT = function(res, ...)     log('mqtt connect status', res, ...)     if res then       for addr, topic in pairs(object_to_mqtt) do         local value = grp.getvalue(addr)         if value ~= nil then           if type(value) == 'boolean' then             value = value and 1 or 0           end           mclient:publish(topic, tostring(value), 0, true)         end       end       for topic, _ in pairs(mqtt_to_object) do         mclient:subscribe(topic)       end     else       mclient:disconnect()     end   end
RE: MQTT Broker Project with 2024 FW Problem - by admin - 20.09.2024, 08:55
