API Control camera Vivotek
Run this script as resident. Change host variable to your camera IP and auth variable to access credentials in username:password format. Make sure that Basic auth mode (not digest) is set on your camera. Then post what you get in LM Logs when running this script.
local json = require('json') local socket = require('socket') local mime = require('mime') local host = '192.168.1.1' local auth = 'user:password' local sock = socket.tcp() sock:settimeout(15) local res, err = sock:connect(host, 80) if not res then   sock:close()   log('connect failed', err)   os.sleep(5)   return end local function init()   local crlf = '\r\n'   sock:send(     'GET /FR/events/live/json?heartbeat=10 HTTP/1.1' .. crlf ..     'Host: ' .. host .. crlf ..     'Authorization: Basic ' .. mime.b64(auth) .. crlf .. crlf   ) end local function parse(resp)   resp = json.pdecode(resp)   log(resp) end init() local pat, len = nil, nil while true do   res, err = sock:receive(pat)   log('rx', pat, res, err)   if err then     sock:close()     log('receive error', err)     break   end   if type(pat) == 'number' then     pcall(parse, res)     pat, len = nil, nil   elseif #res == 0 then     pat = len   elseif not len then     len = res:match('Content%-Length: (%d+)')     len = tonumber(len)   end end
API Control camera Vivotek - by luanpt - 29.09.2024, 12:06
RE: API Control camera Vivotek - by admin - 30.09.2024, 07:43
RE: API Control camera Vivotek - by luanpt - 01.10.2024, 02:13
RE: API Control camera Vivotek - by admin - 02.10.2024, 11:52
RE: API Control camera Vivotek - by luanpt - 05.10.2024, 05:32
RE: API Control camera Vivotek - by admin - 07.10.2024, 06:33
RE: API Control camera Vivotek - by luanpt - 10.10.2024, 10:01
RE: API Control camera Vivotek - by admin - 10.10.2024, 13:04
RE: API Control camera Vivotek - by luanpt - 12.10.2024, 05:09
