9 hours ago
(14.10.2024, 06:55)admin Wrote: This can be done with 2 resident scripts:
1. OR gate for light groups: https://kb.logicmachine.net/scripting/lo...-statuses/
2. Modified staircase timer that uses status from the OR gate: https://kb.logicmachine.net/scripting/staircase-timer/
We can help with the modifications but you need describe the vent logic in more detail:
- Is the timer setting global for all vents or adjustable for each vent separately?
- What should happen if the light switches on while the vent is already running? Should the timer continue running or stop?
- What should happen if the light switches off while the vent is already running? Should the timer continue running as is or should it reset to the starting value?
thaks for your answer. I look for scripts, but I need help with edit this script.
Time is same for all vents.
In both of case we want to retrigger running time and then switch off.
