Master Slave with LM5
(06.11.2024, 11:21)Daniel Wrote: Can you provide more info how the DALI, BACnet and modbus is done?
KNX sensors control the lighting via DALI. In the event of a failure, the second LM should take over the control and visualization.
The LM communicates with the Schneider Gateway via BACnet. Modbus is used for communication with field devices.
In case of a Master LM failure, everything should continue to operate via the Slave LM. Sensor values are visualized.
Master Slave with LM5 - by Kuru - 06.11.2024, 10:06
RE: Master Slave with LM5 - by Daniel - 06.11.2024, 11:21
RE: Master Slave with LM5 - by Kuru - 06.11.2024, 12:38
RE: Master Slave with LM5 - by Daniel - 06.11.2024, 12:42
RE: Master Slave with LM5 - by Kuru - 07.11.2024, 13:05
RE: Master Slave with LM5 - by Daniel - 07.11.2024, 14:34
RE: Master Slave with LM5 - by Kuru - 24.04.2025, 11:26
RE: Master Slave with LM5 - by Daniel - 24.04.2025, 12:16
RE: Master Slave with LM5 - by Kuru - 24.04.2025, 12:43
RE: Master Slave with LM5 - by Daniel - 24.04.2025, 12:45
RE: Master Slave with LM5 - by Kuru - 24.04.2025, 13:02
RE: Master Slave with LM5 - by Daniel - 25.04.2025, 09:09
RE: Master Slave with LM5 - by Kuru - 28.04.2025, 10:52
RE: Master Slave with LM5 - by Daniel - 28.04.2025, 11:01
RE: Master Slave with LM5 - by Kuru - 08.05.2025, 09:16
RE: Master Slave with LM5 - by Daniel - 08.05.2025, 12:53
RE: Master Slave with LM5 - by admin - 14.05.2025, 10:28
RE: Master Slave with LM5 - by Kuru - 14.08.2025, 09:39
