E-mail with attachment
I've changed a little original script for sending an email. Below script can send an email to a few recipients with a few files in the attachement not only one file. You can use it for example for sending images from a few cameras or sending camera image and .csv file.
This script is an updated version of above script from Edgars:
-- send an e-mail with attachments function mailattach(to, subject, message, files)  -- make sure these settings are correct  local settings = {    -- "from" field, only e-mail must be specified here    from = 'user@gmail.com',    -- smtp username    user = 'user@gmail.com',    -- smtp password    password = 'user',    -- smtp server    server = 'smtp.gmail.com',    -- smtp server port    port = 465,    -- enable ssl, required for gmail smtp    secure = 'sslv23',  }  local smtp = require('socket.smtp')  if type(to) ~= 'table' then    to = { to }  end  for index, email in ipairs(to) do    to[ index ] = '<' .. tostring(email) .. '>'  end  -- escape double quotes in file name for _, object in ipairs(table) do  files[_].filename = files[_].filename:gsub('"', '\\"')  end  -- message headers and body email = {headers = {}, body = {}} email.headers = { to = table.concat(to, ', '), subject = subject, } email.body[1] = { headers = { ['Content-Type'] = 'text/html; charset=utf-8', }, body = mime.eol(0, message) } -- adding attachements for _, object in ipairs(files) do email.body[_+1] = {    headers = { ['Content-Type'] = files[_].mimetype or 'text/plain', ['Content-Disposition'] = 'attachment; filename="' .. files[_].filename ..'"', ['Content-Transfer-Encoding'] = 'BASE64', },    body = ltn12.source.chain( ltn12.source.string(files[_].filedata), ltn12.filter.chain(mime.encode('base64'), mime.wrap() ) )  } end settings.source = smtp.message(email)  -- fixup from field  settings.from = '<' .. tostring(settings.from) .. '>'  settings.rcpt = to    return smtp.send(settings)  end
Example of use:
-- email parameters to = { 'first@gmail.com', 'second@gmail.com' } subject = 'Email with a few attachements' message = 'Email with a few attachements. Please check them.' files = { {filename = 'Image1.jpg', filedata = io.readfile('/www/scada/resources/img/Image1.jpg'), mimetype = 'jpg'}, {filename = 'Image2.jpg', filedata = io.readfile('/www/scada/resources/img/Image2.jpg'), mimetype = 'jpg'} } -- send an e-mail with attachments mailattach(to, subject, message, files)
E-mail with attachment - by admin - 21.09.2016, 06:34
RE: E-mail with attachment - by buuuudzik - 11.03.2017, 07:29
RE: E-mail with attachment - by buuuudzik - 15.03.2017, 09:35
RE: E-mail with attachment - by admin - 15.03.2017, 10:46
RE: E-mail with attachment - by buuuudzik - 15.03.2017, 11:00
RE: E-mail with attachment - by admin - 15.03.2017, 11:06
RE: E-mail with attachment - by buuuudzik - 15.03.2017, 11:12
RE: E-mail with attachment - by Keitz - 22.10.2017, 18:11
RE: E-mail with attachment - by buuuudzik - 17.03.2017, 16:59
RE: E-mail with attachment - by buuuudzik - 22.10.2017, 18:24
RE: E-mail with attachment - by iJAF - 06.04.2022, 17:31
RE: E-mail with attachment - by admin - 11.04.2022, 09:44
