Trends API
#34
Can you try this version, it uses webrequests instead of URL with basic authentication that is not supported anymore in FW 3.0.0
-- Batch adding trends v1.3 - Created by Erwin van der Zwart - Schneider Electric Netherlands ------------------- -- For spaceLYnk FW 3.0.0 or higher and Wiser for KNX FW 3.0.0 or higher ---------------------------------------- -- Make sure that "Block unsafe functions in scripts" is disbled in General Configuration -- Refresh browser after creation to show the trends ------------------------------------------------------------ ----------------------------------------------- Start Parameters ------------------------------------------------ -- Start address of objects start_objectaddress = '3/0/0' -- Trends for all objects between these range are created -- End address of objects end_objectaddress = '3/0/2' -- Select trend type to create (or multiple types on same object) create_trendtype_counter = false create_trendtype_counter_with_negative_delta = false create_trendtype_absolute_value = true -- Select aggregate function (!Important! Can only be these values: AVERAGE / MIN / MAX / LAST)) trendaggregatefunction = 'AVERAGE' -- Set trend resolution (!Important! Can only be these values: 5 / 10 / 15 / 20 / 30 / 60 minutes)) trendresolution = 5 -- Set trend precicion (!Important! Can only be these values: 0 to 8) decimal places trendprecision = 2 -- Set trend count resolution (!Important! Can only be these values: '30' = 30 days, '180' = 180 days, '365' = 1 year, '730' = 2 years, '1825' = 5 years trendcountresolution = 365 -- Set trend count days (!Important! Can only be these values: '1' = 1 year / '2' = 2 years / '5' = 5 years / '10' = 10 years) trendcountdaily = 10 -- Set show always 0 base line trendshowzero = 0 -- 0 = disabled 1 = enabled ------------------------------------------------ End Parameters ------------------------------------------------- ------------------------------------ DON'T CHANGE ANYTHING UNDER THIS LINE -------------------------------------- -- Calculate start address to DB format start_objectaddress = knxlib.encodega(start_objectaddress) -- Calculate end address to DB format end_objectaddress = knxlib.encodega(end_objectaddress) -- Function to send request (in this case to create a trend) function webrequest(mod, act, vars, data)   require('json')   require('dbenv')   local path   vars = vars or {}   function getvar(v)       return vars[ v ]   end   json.data = function()       return data or {}   end   if mod == 'plugin' then   path = 'plugins/' .. act .. '/web.lua'   else    path = 'web/' .. mod .. '/' .. act .. '.lua'   end   result = dofile('/lib/genohm-scada/' .. path)   -- Calculate results for creation results log   if result.success == true then     number_of_trends = number_of_trends + 1   else     number_failed = number_failed + 1   end end -- Function to create vars function createvars(trend_object, trend_name, trend_type, trend_aggregate_function, trend_resolution, trend_precision, trend_count_resolution, trend_count_daily, trend_show_zero, trend_id)   local vars = {       object = trend_object,       name = trend_name,       type = trend_type,       aggregation = trend_aggregate_function,       resolution = trend_resolution,       precision = trend_precision,     count_resolution = trend_count_resolution * 12 * 24, -- nr of days * nr of points in a hour at min resolution (60/5 = 12) * hours per day     count_daily = trend_count_daily * 365, -- nr of days * 365 days a year       show_zero = trend_show_zero,       id = trend_id,     }   return vars end -- Set counters for creation log number_of_trends = 0 number_failed = 0 -- Loop from startadres to end address to create trends for i = start_objectaddress, end_objectaddress, 1 do     -- Get current group address from loop   current_GA = knxlib.decodega(i)     -- Get current object info   objectinfo = grp.find(current_GA)        -- Check if object excists   if objectinfo ~= nil then            -- Set parameters for request     trendobject = objectinfo.id     trendname = objectinfo.name     trendid = ''         -- Check if trend type 'Counter' should be created     if create_trendtype_counter == true then       -- Call function to create vars       requestdata = createvars(trendobject, trendname, 'C', trendaggregatefunction, trendresolution, trendprecision, trendcountresolution, trendcountdaily, trendshowzero, trendid)       webrequest('trends', 'save', {request = 'save'}, requestdata)     end         -- Check if trend type 'Counter with negative delta' should be created     if create_trendtype_counter_with_negative_delta == true then             -- Call function to send create vars       requestdata = createvars(trendobject, trendname, 'D', trendaggregatefunction, trendresolution, trendprecision, trendcountresolution, trendcountdaily, trendshowzero, trendid)       webrequest('trends', 'save', {request = 'save'}, requestdata)     end         -- Check if trend type 'Absolute value' should be created     if create_trendtype_absolute_value == true then             -- Call function to send create vars       requestdata = createvars(trendobject, trendname, 'G', trendaggregatefunction, trendresolution, trendprecision, trendcountresolution, trendcountdaily, trendshowzero, trendid)       webrequest('trends', 'save', {request = 'save'}, requestdata)     end       end   end     if number_failed == 0 then     log ("Created " .. number_of_trends .. " trends succesfully") else     log ("Created " .. number_of_trends .. " trends succesfully and creation of " .. number_failed .. " trends failed") end -- Disable script when done automaticly script.disable(_SCRIPTNAME)
Trends API - by buuuudzik - 28.05.2016, 16:52
RE: Trends API - by Habib - 28.05.2016, 17:13
RE: Trends API - by Erwin van der Zwart - 28.05.2016, 22:01
RE: Trends API - by admin - 29.05.2016, 06:12
RE: Trends API - by buuuudzik - 29.05.2016, 11:22
RE: Trends API - by Erwin van der Zwart - 02.09.2016, 18:46
RE: Trends API - by admin - 05.09.2016, 06:01
RE: Trends API - by Erwin van der Zwart - 05.09.2016, 09:29
RE: Trends API - by Pawel - 07.12.2016, 20:15
RE: Trends API - by Domoticatorino - 19.02.2018, 15:39
RE: Trends API - by Erwin van der Zwart - 19.02.2018, 16:32
RE: Trends API - by Domizy - 18.12.2024, 14:24
RE: Trends API - by Domoticatorino - 13.02.2018, 16:52
RE: Trends API - by Daniel - 13.02.2018, 18:49
RE: Trends API - by Domoticatorino - 19.02.2018, 16:33
RE: Trends API - by PassivPluss - 17.09.2019, 21:10
RE: Trends API - by admin - 24.09.2019, 06:53
RE: Trends API - by Trond Hoyem - 17.06.2022, 12:57
RE: Trends API - by admin - 17.06.2022, 13:20
RE: Trends API - by Trond Hoyem - 17.06.2022, 13:23
RE: Trends API - by admin - 17.06.2022, 13:23
RE: Trends API - by Trond Hoyem - 17.06.2022, 13:27
RE: Trends API - by admin - 17.06.2022, 13:30
RE: Trends API - by Trond Hoyem - 17.06.2022, 13:33
RE: Trends API - by admin - 17.06.2022, 13:34
RE: Trends API - by Trond Hoyem - 17.06.2022, 13:36
RE: Trends API - by admin - 17.06.2022, 14:15
RE: Trends API - by Trond Hoyem - 17.06.2022, 14:26
RE: Trends API - by admin - 17.06.2022, 14:32
RE: Trends API - by Daniel - 18.12.2024, 14:51
RE: Trends API - by Domizy - 18.12.2024, 15:06
RE: Trends API - by Daniel - 18.12.2024, 15:29
RE: Trends API - by Domizy - 18.12.2024, 15:39
RE: Trends API - by Erwin van der Zwart - 19.12.2024, 14:57
RE: Trends API - by Domizy - 19.12.2024, 17:30
RE: Trends API - by avolle - 03.12.2025, 18:22
RE: Trends API - by admin - 04.12.2025, 08:07
