System parameters
(13.03.2017, 10:33)Thomas Wrote: Hi
How about KNX BUS load? Is there this value available in LM?
Thank you.
You can also do something like this:
-- Checking how many object from database was updated in last 5 seconds delta=os.microtime() - 5 query = "SELECT name FROM objects WHERE updatetime>" .. delta updated = db:getall(query) log(#updated)
It gives an info about how many objects from database was updated in the last 5 seconds(if 1 object was updated a few times in this 5 seconds it would't be counted). You can also change this 5 second to other value e.g. 1s.
System parameters - by baggins - 09.03.2017, 12:37
RE: System parameters - by baggins - 12.03.2017, 22:26
RE: System parameters - by buuuudzik - 13.03.2017, 07:16
RE: System parameters - by admin - 13.03.2017, 07:31
RE: System parameters - by baggins - 13.03.2017, 07:58
RE: System parameters - by admin - 13.03.2017, 07:59
RE: System parameters - by baggins - 13.03.2017, 08:12
RE: System parameters - by Thomas - 13.03.2017, 10:33
RE: System parameters - by buuuudzik - 13.03.2017, 19:29
RE: System parameters - by admin - 13.03.2017, 10:59
