Scripting
thank you for your help! I will heed your you help once again
I ended up with the below script that is a event based on the setpoint to change the offset but only if the actual temperature is higher than the setpoint here is the script that i made that doesnt work.
local setpoint = event.getvalue() local actual_temp = '12/0/5' local zone1 = grp.getvalue('3/3/1') - (0.1) local temp_diff = setpoint - actual_temp    if temp_diff <= 0.1   then grp.write('3/3/1',zone1) end
thank you advance
Scripting - by mariosp - 16.01.2025, 09:17
RE: Scripting - by RomansP - 16.01.2025, 10:05
RE: Scripting - by mariosp - 16.01.2025, 10:57
RE: Scripting - by Daniel - 16.01.2025, 11:02
RE: Scripting - by mariosp - 16.01.2025, 11:22
RE: Scripting - by Daniel - 16.01.2025, 11:29
RE: Scripting - by mariosp - 16.01.2025, 11:37
RE: Scripting - by Daniel - 16.01.2025, 11:43
RE: Scripting - by mariosp - 16.01.2025, 11:54
RE: Scripting - by RomansP - 16.01.2025, 11:59
RE: Scripting - by mariosp - 16.01.2025, 12:04
RE: Scripting - by RomansP - 16.01.2025, 12:09
RE: Scripting - by mariosp - 16.01.2025, 12:11
RE: Scripting - by Daniel - 16.01.2025, 12:23
RE: Scripting - by RomansP - 16.01.2025, 12:26
RE: Scripting - by mariosp - 17.01.2025, 12:15
RE: Scripting - by RomansP - 17.01.2025, 12:37
RE: Scripting - by mariosp - 18.01.2025, 08:14
RE: Scripting - by baggins - 18.01.2025, 10:11
RE: Scripting - by mariosp - 18.01.2025, 11:11
RE: Scripting - by admin - 18.01.2025, 11:12
RE: Scripting - by mariosp - 20.01.2025, 09:10
RE: Scripting - by RomansP - 20.01.2025, 10:07
RE: Scripting - by mariosp - 20.01.2025, 12:08
RE: Scripting - by admin - 20.01.2025, 12:24
RE: Scripting - by mariosp - 20.01.2025, 13:55
RE: Scripting - by admin - 20.01.2025, 13:57
RE: Scripting - by Erwin van der Zwart - 20.01.2025, 15:10
RE: Scripting - by mariosp - 20.01.2025, 15:25
RE: Scripting - by mariosp - 21.01.2025, 11:19
RE: Scripting - by admin - 21.01.2025, 11:31
