Scripting
#22
(18.01.2025, 11:12)admin Wrote: Explain exactly what do you want this script to do.
so its a littlebit complicated.
I have underfloor heating i want the pwm valves to not close and i want to change the %of the opening valve i want if the actual temperature
is higher than then setpoint to write to the group address of the heating actuator the setpoint - the offset that my client will set
but if the actual temperature is lower than the set i want to write to  group address of the heating actuator the actual temperature so it will open more if need it heres is the script that i end up. Thank you in advance!
if event.getvalue() then -- actual temperature of room1   local actual_temp1 = grp.getvalue('12/0/5')   -- group address of the heating actuator for temperature   local fake_temp_addr1 = '3/3/1' -- virtual group address that i created for mosaic   local offsetvalue = grp.getvalue('32/1/69') -- master setpoint for all rooms       local value_temp = grp.getvalue('12/1/0')   --setpoint of room   local value_temp1 = grp.getvalue('3/1/1') -- for mosaic because that i made it with rotary dimmer   local offset = value_temp - offsetvalue * 0.01 if actual_temp1 >= value_temp or  value_temp1   then grp.write(fake_temp_addr1,offset)   else   grp.write(fake_temp_addr1,actual_temp1)
Scripting - by mariosp - 16.01.2025, 09:17
RE: Scripting - by RomansP - 16.01.2025, 10:05
RE: Scripting - by mariosp - 16.01.2025, 10:57
RE: Scripting - by Daniel - 16.01.2025, 11:02
RE: Scripting - by mariosp - 16.01.2025, 11:22
RE: Scripting - by Daniel - 16.01.2025, 11:29
RE: Scripting - by mariosp - 16.01.2025, 11:37
RE: Scripting - by Daniel - 16.01.2025, 11:43
RE: Scripting - by mariosp - 16.01.2025, 11:54
RE: Scripting - by RomansP - 16.01.2025, 11:59
RE: Scripting - by mariosp - 16.01.2025, 12:04
RE: Scripting - by RomansP - 16.01.2025, 12:09
RE: Scripting - by mariosp - 16.01.2025, 12:11
RE: Scripting - by Daniel - 16.01.2025, 12:23
RE: Scripting - by RomansP - 16.01.2025, 12:26
RE: Scripting - by mariosp - 17.01.2025, 12:15
RE: Scripting - by RomansP - 17.01.2025, 12:37
RE: Scripting - by mariosp - 18.01.2025, 08:14
RE: Scripting - by baggins - 18.01.2025, 10:11
RE: Scripting - by mariosp - 18.01.2025, 11:11
RE: Scripting - by admin - 18.01.2025, 11:12
RE: Scripting - by mariosp - 20.01.2025, 09:10
RE: Scripting - by RomansP - 20.01.2025, 10:07
RE: Scripting - by mariosp - 20.01.2025, 12:08
RE: Scripting - by admin - 20.01.2025, 12:24
RE: Scripting - by mariosp - 20.01.2025, 13:55
RE: Scripting - by admin - 20.01.2025, 13:57
RE: Scripting - by Erwin van der Zwart - 20.01.2025, 15:10
RE: Scripting - by mariosp - 20.01.2025, 15:25
RE: Scripting - by mariosp - 21.01.2025, 11:19
RE: Scripting - by admin - 21.01.2025, 11:31
