Executing command on remote server fails
You have a separate device that runs your Lua script. You can create a TCP server that forwards messages.
Server code (change token and chat_id as needed):
require('socket') require('ssl.https') token = 'token' -- your token chat_id = '1234567' -- your chat id function telegram(message)   local url = 'https://api.telegram.org/bot' .. token .. '/sendMessage'   local data = 'chat_id=' .. chat_id .. '&text=' .. socket.url.escape(message)   return ssl.https.request(url, data) end server = socket.bind('*', 8000) while true do   client = server:accept()   client:settimeout(1)   message, err = client:receive('*a')   if message then     telegram(message)   end   client:close() end
Client code (change ip and message as needed):
require('socket') ip = '127.0.0.1' message = 'hello' client = socket.tcp() client:settimeout(5) res, err = client:connect(ip, 8000) if res then   client:send(message) end client:close()
RE: Executing command on remote server fails - by admin - 20.01.2025, 12:54
