Scripting
#26
(20.01.2025, 12:24)admin Wrote: If there are two setpoints then you need to know which one is currently used. Does your heating actuator have a setpoint status output?
yes and i tryed now but it work only for first one room of the script here is the full script!
if event.getvalue() then local actual_temp1 = grp.getvalue('12/0/5') local fake_temp_addr1 = '3/3/1' local offsetvalue = grp.getvalue('32/1/69') local value_temp = grp.getvalue('12/1/0') local value_temp1 = grp.getvalue('3/1/1') local offset = value_temp - offsetvalue * 0.01 local temp_dif = value_temp - actual_temp1 local setpointstatus1 = grp.getvalue('4/2/1')   if actual_temp1 >= setpointstatus1   then grp.write(fake_temp_addr1,offset) else   grp.write(fake_temp_addr1,actual_temp1)   local actual_temp2 = grp.getvalue('12/0/3') local fake_temp_addr2 = '3/3/2' local offsetvalue = grp.getvalue('32/1/69') local value_temp = grp.getvalue('12/1/0') local value_temp2 = grp.getvalue('3/1/2') local offset = value_temp - offsetvalue * 0.01 local temp_dif = value_temp - actual_temp2 local setpointstatus2 = grp.getvalue('4/2/2')     if actual_temp2 >= setpointstatus2   then grp.write(fake_temp_addr2,offset)   else   grp.write(fake_temp_addr2,actual_temp2)   local actual_temp3 = grp.getvalue('12/0/4') local fake_temp_addr3 = '3/3/3' local offsetvalue = grp.getvalue('32/1/69') local value_temp = grp.getvalue('12/1/0') local value_temp3 = grp.getvalue('3/1/3') local offset = value_temp - offsetvalue * 0.01 local temp_dif = value_temp - actual_temp3 local setpointstatus3 = grp.getvalue('4/2/3')       if actual_temp3 > setpointstatus3   then grp.write(fake_temp_addr3,offset)   else   grp.write(fake_temp_addr3,actual_temp3)       local actual_temp4 = grp.getvalue('12/0/4') local fake_temp_addr4 = '3/3/4' local offsetvalue = grp.getvalue('32/1/69') local value_temp = grp.getvalue('12/1/0') local value_temp4 = grp.getvalue('3/1/4') local offset = value_temp - offsetvalue * 0.01 local temp_dif = value_temp - actual_temp4 local setpointstatus4 = grp.getvalue('4/2/4')         if actual_temp4 >= setpointstatus4   then grp.write(fake_temp_addr4,offset)   else   grp.write(fake_temp_addr4,actual_temp4)                         local actual_temp5 = grp.getvalue('12/0/1') local fake_temp_addr5 = '3/3/5' local offsetvalue = grp.getvalue('32/1/69') local value_temp = grp.getvalue('12/1/0') local value_temp5 = grp.getvalue('3/1/5') local offset = value_temp - offsetvalue * 0.01 local temp_dif = value_temp - actual_temp5 local setpointstatus5 = grp.getvalue('4/2/5')                     if actual_temp5 >= setpointstatus5   then grp.write(fake_temp_addr5,offset)   else   grp.write(fake_temp_addr5,actual_temp5) local actual_temp6 = grp.getvalue('12/0/3') local fake_temp_addr6 = '3/3/6' local offsetvalue = grp.getvalue('32/1/69') local value_temp = grp.getvalue('12/1/0') local value_temp6 = grp.getvalue('3/1/6') local offset = value_temp - offsetvalue * 0.01 local temp_dif = value_temp - actual_temp6 local setpointstatus6 = grp.getvalue('4/2/6') if actual_temp5 >= setpointstatus6   then grp.write(fake_temp_addr6,offset)   else   grp.write(fake_temp_addr6,actual_temp6)                         local actual_temp7 = grp.getvalue('12/0/2') local fake_temp_addr7 = '3/3/7' local offsetvalue = grp.getvalue('32/1/69') local value_temp = grp.getvalue('12/1/0') local value_temp7 = grp.getvalue('3/1/7') local offset = value_temp - offsetvalue * 0.01 local temp_dif = value_temp - actual_temp7 local setpointstatus7 = grp.getvalue('4/2/7') if actual_temp7 >= value_temp or value_temp7   then grp.write(fake_temp_addr7,offset)   else   grp.write(fake_temp_addr7,actual_temp7)         local actual_temp8 = grp.getvalue('12/0/3') local fake_temp_addr8 = '3/3/8' local offsetvalue = grp.getvalue('32/1/69') local value_temp = grp.getvalue('12/1/0') local value_temp8 = grp.getvalue('3/1/8') local offset = value_temp - offsetvalue * 0.01 local temp_dif = value_temp - actual_temp8 local setpointstatus8 = grp.getvalue('4/2/8')                 if actual_temp8 >= setpointstatus8   then grp.write(fake_temp_addr8,offset)   else   grp.write(fake_temp_addr8,actual_temp8)                                 local actual_temp9 = grp.getvalue('12/0/3') local fake_temp_addr9 = '3/3/9' local offsetvalue = grp.getvalue('32/1/69') local value_temp = grp.getvalue('12/1/0') local value_temp9 = grp.getvalue('3/1/9') local offset = value_temp - offsetvalue * 0.01 local temp_dif = value_temp - actual_temp9 local setpointstatus9  = grp.getvalue('4/2/9')                   if actual_temp9 >= setpointstatus9 then grp.write(fake_temp_addr9,offset)   else   grp.write(fake_temp_addr9,actual_temp9)                   end            end end     end      end        end       end     end   end end
Scripting - by mariosp - 16.01.2025, 09:17
RE: Scripting - by RomansP - 16.01.2025, 10:05
RE: Scripting - by mariosp - 16.01.2025, 10:57
RE: Scripting - by Daniel - 16.01.2025, 11:02
RE: Scripting - by mariosp - 16.01.2025, 11:22
RE: Scripting - by Daniel - 16.01.2025, 11:29
RE: Scripting - by mariosp - 16.01.2025, 11:37
RE: Scripting - by Daniel - 16.01.2025, 11:43
RE: Scripting - by mariosp - 16.01.2025, 11:54
RE: Scripting - by RomansP - 16.01.2025, 11:59
RE: Scripting - by mariosp - 16.01.2025, 12:04
RE: Scripting - by RomansP - 16.01.2025, 12:09
RE: Scripting - by mariosp - 16.01.2025, 12:11
RE: Scripting - by Daniel - 16.01.2025, 12:23
RE: Scripting - by RomansP - 16.01.2025, 12:26
RE: Scripting - by mariosp - 17.01.2025, 12:15
RE: Scripting - by RomansP - 17.01.2025, 12:37
RE: Scripting - by mariosp - 18.01.2025, 08:14
RE: Scripting - by baggins - 18.01.2025, 10:11
RE: Scripting - by mariosp - 18.01.2025, 11:11
RE: Scripting - by admin - 18.01.2025, 11:12
RE: Scripting - by mariosp - 20.01.2025, 09:10
RE: Scripting - by RomansP - 20.01.2025, 10:07
RE: Scripting - by mariosp - 20.01.2025, 12:08
RE: Scripting - by admin - 20.01.2025, 12:24
RE: Scripting - by mariosp - 20.01.2025, 13:55
RE: Scripting - by admin - 20.01.2025, 13:57
RE: Scripting - by Erwin van der Zwart - 20.01.2025, 15:10
RE: Scripting - by mariosp - 20.01.2025, 15:25
RE: Scripting - by mariosp - 21.01.2025, 11:19
RE: Scripting - by admin - 21.01.2025, 11:31
