Read from the logic machine
Here's the documentation on serial library:
http://openrb.com/docs/serial.htm
Here's a small example that will send back everything that LM reads from RS232 (default serial settings are 115200 8N1):
-- open port on first call if not port then   require('serial')   port = serial.open('/dev/RS232')   port:flush() end -- port ready if port then   -- read one byte   char = port:read(1, 1)   -- send back if read succeeded   if char then     port:write(char)   end end
Read from the logic machine - by Rodriguez - 16.03.2017, 13:47
RE: Read from the logic machine - by admin - 16.03.2017, 13:51
RE: Read from the logic machine - by admin - 16.03.2017, 14:11
