07.03.2025, 06:59
(04.03.2025, 07:38)admin Wrote: Make sure you have the latest firmware and "Pass ind. telegrams via IP Routing" is enabled in System config > Network > KNX connection.
LM KNX address must be in the same range as the local TP network.
Hi! and thank you for your reply.
As for the Firmaware we have the 20240426 , is this OK or not?
And the parameter you told me to have as enabled is already enabled.
Also I changed physical address to 1.2.255 for programming the KNX of Line 2 but it didn't worked. Also I changed the physical address to 1.1.25 for programming the KNX devices of Line 1 the same issue.
