LM5 as KNX/IP Router
(07.03.2025, 09:36)Daniel Wrote: If you use repeaters then you should have only one line 1.1 not 1.1, 1,2 and 1.3
Yes so maybe this is the problem but I tried to change it to Line couplers and I had the same issue. And also I set the telegrams route and not filtered to avoid this issue but it didn't worked
LM5 as KNX/IP Router - by vmic - 04.03.2025, 06:35
RE: LM5 as KNX/IP Router - by admin - 04.03.2025, 07:38
RE: LM5 as KNX/IP Router - by vmic - 07.03.2025, 06:59
RE: LM5 as KNX/IP Router - by admin - 07.03.2025, 07:22
RE: LM5 as KNX/IP Router - by Daniel - 07.03.2025, 08:22
RE: LM5 as KNX/IP Router - by vmic - 07.03.2025, 09:25
RE: LM5 as KNX/IP Router - by Daniel - 07.03.2025, 09:36
RE: LM5 as KNX/IP Router - by vmic - 07.03.2025, 09:48
RE: LM5 as KNX/IP Router - by Daniel - 07.03.2025, 10:00
