Conversion
(12.03.2025, 18:06)Daniel Wrote: Use modbus profile app and in there you have bit converter. Just select the bits you need.
Ok I never saw this function, I check better.
Best regards Cristian
I've checked, but I've found a strange behavior... If register type it is Holding register I can insert value bitmask, instead type it os input register the app says to create the bitmask but if I download the profile this parameter there is not. Anyway this solution can work.
p.s. I downloaded the profile edit with notepad++ and works also with type input register. (I think there is a little bug in the app)
Conversion - by CristianAgata - 12.03.2025, 17:54
RE: Conversion - by Daniel - 12.03.2025, 18:06
RE: Conversion - by CristianAgata - 12.03.2025, 18:20
RE: Conversion - by Daniel - 13.03.2025, 11:18
RE: Conversion - by CristianAgata - 13.03.2025, 12:47
