Modbus function code 23 (#17)
I partially solved it using the send() function sending a string to the device.
In debug I can see the response which is complete and correct but the mb:receive() function returns a timeout error.
require('luamodbus') function hexToString(hex)     -- Remove any spaces or invalid characters     hex = hex:gsub("([^0-9a-fA-F])", "")         -- Convert each pair of hex digits into a character     local str = ""     for i = 1, #hex, 2 do         local byte = hex:sub(i, i + 1)         str = str .. string.char(tonumber(byte, 16))     end     return str end buffer = {} function logger(c)     table.insert(buffer, c) end local mb2 = luamodbus.rtu() mb2:open('/dev/RS485-2', 19200, 'E', 8, 1, 'H') mb2:connect() mb2:setslave(1) mb2:setreceivetimeout(1.0) mb2:setresponsetimeout(1.0) mb2:setdebug(logger) local variable_number = '11'  -- in hexadecimal hex_decoded = hexToString("011700000006000000060c0a01ae0f000000" .. variable_number .. "00000000") -- Sending variabile,err_s=mb2:send(hex_decoded) -- Response local response,err = mb2:receive() -- Log the sending operation if variabile then     log("Is send successful?: ")     log(variabile) else     log("Sending error: "..err_s) end -- Log the response if response then     log("Response from device: " .. table.concat(response, ", ")) else     log("Response error: ".. err_r) end log(table.concat(buffer)) mb2:close()
Logs report:
Response error: Operation timed out
Debug:
* string: [01][17][00][00][00][06][00][00][00][06][0C][0A][01][AE][0F][00][00][00][11][00][00][00][00][91][AF]
Waiting for a indication...
<01><17><0C><0A><01><AE><0F><00><00><00><11><00><00><00><42><C1><35>ERROR Operation timed out: select
The response captured by debug is complete and correct.
I tried to change setreceivetimeout() and setresponsetimeout() with no effects.
Modbus function code 23 (#17) - by alb-smith - 27.03.2025, 09:13
RE: Modbus function code 23 (#17) - by admin - 27.03.2025, 09:18
RE: Modbus function code 23 (#17) - by admin - 28.03.2025, 11:14
RE: Modbus function code 23 (#17) - by alb-smith - 29.03.2025, 09:36
RE: Modbus function code 23 (#17) - by admin - 31.03.2025, 07:36
