TCP Modbus
Information
I'm trying to make a connection with Modbus TCP slave device.
I tried to do so with scripts (you can see it below) and visual mapper.
In visual mapper I tried many different combinations in device profile, but couldn't get right value:
{ "name": "Input 1", "bus_datatype": "float16", "type": "register", "address": 128, "datatype": "float16", "value_multiplier": 1, "units": " C" }, { "name": "Input 1", "bus_datatype": "uint16", "type": "register", "address": 128, "datatype": "float16", "value_multiplier": 1, "units": " C" }, { "name": "Input 1", "bus_datatype": "int16", "type": "register", "address": 128, "datatype": "int16", "value_multiplier": 1, "units": " C" } and etc..
Full script (IP address of device is corrent - 192.168.1.210, port - 502, slave ID - 20):
require('luamodbus') if not mb then     mb = luamodbus.tcp()     mb:open('192.168.1.210')     mb:connect() end -- verbose output and select slave number 10 mb:setdebug(true) mb:setslave(20) -- read input from reg 1 to 5, get slave-specific data local result = mb:readregistervalue(128, dt.float16) grp.write('14/1/0', result, dt.float16) local value = mb:reportslaveid() alert(value) -- close serial connection mb:close()
TCP Modbus - by leondias - 21.03.2017, 14:08
RE: TCP Modbus - by admin - 21.03.2017, 14:34
RE: TCP Modbus - by leondias - 21.03.2017, 14:39
RE: TCP Modbus - by unaxboy - 29.11.2017, 12:44
RE: TCP Modbus - by admin - 21.03.2017, 14:42
RE: TCP Modbus - by leondias - 21.03.2017, 14:47
RE: TCP Modbus - by admin - 21.03.2017, 15:59
RE: TCP Modbus - by leondias - 22.03.2017, 07:38
RE: TCP Modbus - by unaxboy - 13.11.2017, 04:18
RE: TCP Modbus - by admin - 29.11.2017, 13:09
RE: TCP Modbus - by unaxboy - 29.11.2017, 13:32
RE: TCP Modbus - by admin - 29.11.2017, 13:35
RE: TCP Modbus - by unaxboy - 29.11.2017, 13:55
RE: TCP Modbus - by admin - 29.11.2017, 15:54
RE: TCP Modbus - by unaxboy - 29.11.2017, 16:47
RE: TCP Modbus - by admin - 29.11.2017, 17:15
RE: TCP Modbus - by unaxboy - 29.11.2017, 18:22
RE: TCP Modbus - by Igor68 - 17.12.2017, 10:22
RE: TCP Modbus - by admin - 18.12.2017, 08:09
RE: TCP Modbus - by SportMaster10 - 12.09.2019, 11:20
RE: TCP Modbus - by AlexLV - 02.07.2020, 08:10
RE: TCP Modbus - by Daniel - 02.07.2020, 08:28
RE: TCP Modbus - by AlexLV - 03.07.2020, 06:56
RE: TCP Modbus - by AlexLV - 03.07.2020, 19:30
