Universal Modbus TCP/RTU Slave
#74
(18.04.2025, 15:16)imprashant Wrote: Hi, I have done the changes in the mbslave (user library script). But still I didn't understand how will I disable one Zone to communicate with the SCADA  over modbus rtu. Do I need to make some changes in resident script as well. Please guide.
Previously the script I was using was working but sometimes I have to send command 2-3 times from Modscan in order to execute command in LM5. The script I was using:
local mb = require('user.mbslave')
local mbrtu = require('luamodbus').rtu()
mbrtu:open('/dev/RS485-1', 9600, 'N', 8, 1, 'H')
mbrtu:connect()
mbrtu:setslave('*') -- Accept multiple RTU slave IDs
mb.setswap('w')
mb.setfloat16precision(2)
local ga1 = '0/0/11' --zone 1 enable/disable
local ga2 = '0/0/12' --zone 2 enable/disable
local current_mapping = nil
-- Predefine mappings for easy reuse
local mapping1 = {
    [1] = {
        coils = {
            [0] = '0/0/1',
        registers = {
            [0] = '0/0/2',
local mapping2 = {
    [1] = {
        coils = {
            [1] = '0/0/3',
        registers = {
            [1] = '0/0/4',
while true do
    local val1 = grp.getvalue(ga1)
    local val2 = grp.getvalue(ga2)
    if not val1 and current_mapping ~= "mapping1" then
        mb.setmapping(mapping1)
        current_mapping = "mapping1"
        log("Applied Mapping 1")
    elseif not val2 and current_mapping ~= "mapping2" then
        mb.setmapping(mapping2)
        current_mapping = "mapping2"
        log("Applied Mapping 2")
    mb.rtuhandler(mbrtu)
    os.sleep(1) -- small delay to prevent CPU hogging
Universal Modbus TCP/RTU Slave - by Daniel - 07.10.2022, 12:55
RE: Universal Modbus TCP Slave - by palomino - 07.10.2022, 17:30
RE: Universal Modbus TCP Slave - by Daniel - 07.10.2022, 17:53
RE: Universal Modbus TCP Slave - by Daniel - 07.10.2022, 17:55
RE: Universal Modbus TCP Slave - by palomino - 10.10.2022, 13:39
RE: Universal Modbus TCP Slave - by Daniel - 10.10.2022, 13:44
RE: Universal Modbus TCP Slave - by palomino - 11.10.2022, 16:22
RE: Universal Modbus TCP Slave - by palomino - 23.02.2023, 12:44
RE: Universal Modbus TCP Slave - by admin - 23.02.2023, 12:47
RE: Universal Modbus TCP Slave - by palomino - 24.02.2023, 12:41
RE: Universal Modbus TCP Slave - by admin - 24.02.2023, 12:48
RE: Universal Modbus TCP Slave - by palomino - 27.02.2023, 13:02
RE: Universal Modbus TCP Slave - by Daniel - 27.02.2023, 13:10
RE: Universal Modbus TCP Slave - by palomino - 27.02.2023, 14:00
RE: Universal Modbus TCP Slave - by Daniel - 27.02.2023, 14:03
RE: Universal Modbus TCP Slave - by palomino - 28.02.2023, 02:32
RE: Universal Modbus TCP Slave - by admin - 28.02.2023, 07:02
RE: Universal Modbus TCP Slave - by Fahd - 06.03.2023, 14:11
RE: Universal Modbus TCP Slave - by Daniel - 06.03.2023, 14:35
RE: Universal Modbus TCP Slave - by Fahd - 06.03.2023, 14:50
RE: Universal Modbus TCP Slave - by Daniel - 06.03.2023, 14:55
RE: Universal Modbus TCP Slave - by Daniel - 06.03.2023, 15:16
RE: Universal Modbus TCP Slave - by Fahd - 07.03.2023, 07:59
RE: Universal Modbus TCP Slave - by rw_echo - 14.03.2023, 05:22
RE: Universal Modbus TCP Slave - by Daniel - 07.03.2023, 11:55
RE: Universal Modbus TCP Slave - by rw_echo - 07.03.2023, 12:32
RE: Universal Modbus TCP Slave - by Daniel - 07.03.2023, 12:34
RE: Universal Modbus TCP Slave - by rw_echo - 07.03.2023, 12:49
RE: Universal Modbus TCP Slave - by Daniel - 07.03.2023, 12:59
RE: Universal Modbus TCP Slave - by David - 13.03.2023, 15:40
RE: Universal Modbus TCP Slave - by admin - 13.03.2023, 15:42
RE: Universal Modbus TCP Slave - by David - 13.03.2023, 15:58
RE: Universal Modbus TCP Slave - by Daniel - 13.03.2023, 16:00
RE: Universal Modbus TCP Slave - by David - 13.03.2023, 16:07
RE: Universal Modbus TCP Slave - by Daniel - 13.03.2023, 16:15
RE: Universal Modbus TCP Slave - by David - 13.03.2023, 16:32
RE: Universal Modbus TCP Slave - by Daniel - 13.03.2023, 16:41
RE: Universal Modbus TCP Slave - by admin - 13.03.2023, 16:45
RE: Universal Modbus TCP Slave - by David - 13.03.2023, 19:31
RE: Universal Modbus TCP Slave - by admin - 14.03.2023, 06:18
RE: Universal Modbus TCP Slave - by rw_echo - 14.03.2023, 07:39
RE: Universal Modbus TCP Slave - by Fahd - 14.03.2023, 08:27
RE: Universal Modbus TCP Slave - by admin - 14.03.2023, 08:15
RE: Universal Modbus TCP Slave - by rw_echo - 14.03.2023, 08:35
RE: Universal Modbus TCP Slave - by admin - 14.03.2023, 08:35
RE: Universal Modbus TCP/RTU Slave - by admin - 06.06.2023, 15:34
RE: Universal Modbus TCP/RTU Slave - by admin - 12.06.2023, 08:59
RE: Universal Modbus TCP/RTU Slave - by admin - 28.03.2024, 08:26
RE: Universal Modbus TCP/RTU Slave - by admin - 12.06.2024, 05:26
RE: Universal Modbus RTU - by Ranjeet - 14.06.2024, 07:24
RE: Universal Modbus TCP/RTU Slave - by admin - 12.07.2024, 07:14
RE: Universal Modbus TCP/RTU Slave - by admin - 16.04.2025, 07:06
RE: Universal Modbus TCP/RTU Slave - by imprashant - 21.04.2025, 09:54
RE: Universal Modbus TCP/RTU Slave - by admin - 22.04.2025, 05:32
RE: Universal Modbus TCP/RTU Slave - by admin - 22.04.2025, 09:01
RE: Universal Modbus TCP/RTU Slave - by admin - 14.08.2025, 09:11
RE: Universal Modbus TCP/RTU Slave - by admin - 25.05.2026, 09:30
RE: Universal Modbus TCP/RTU Slave - by admin - 25.05.2026, 09:47
