Communication with Usb
Use this function to mount USB properly, in alerts you will get either ok or an error message. By default it mounts the first partition from USB drive to /mnt so you don't have to change anything unless you don't want it to work Smile
function mountusb(part, mnt)   part = part or '/dev/sda1'   mnt = mnt or '/mnt'   local cmd = string.format('mount %q %q 2>&1', part, mnt)   local res, stat = io.readproc(cmd)   return stat == 0 and true or nil, res end res, err = mountusb() if res then   alert('USB OK') else   alert('USB error: ' .. tostring(err)) end
Then, to read/write files you need to supply full path like /mnt/myfile.txt. Because in your case path .. 'new.txt' becomes /mntnew.txt which will be written to the main file system instead of USB drive.
Communication with Usb - by Shalltear - 21.03.2017, 14:59
RE: Communication with Usb - by admin - 22.03.2017, 06:55
RE: Communication with Usb - by Shalltear - 22.03.2017, 14:31
RE: Communication with Usb - by admin - 23.03.2017, 07:00
RE: Communication with Usb - by Shalltear - 23.03.2017, 17:06
RE: Communication with Usb - by admin - 24.03.2017, 09:01
RE: Communication with Usb - by Shalltear - 24.03.2017, 16:19
RE: Communication with Usb - by Shalltear - 24.03.2017, 17:57
RE: Communication with Usb - by Shalltear - 28.03.2017, 15:07
