Script reboot failing
What is your LM hardware version (printed on the sticker on the side of the housing)?
Create an event script mapped to a binary object to control USB power power:
state = event.getvalue() and 'high' or 'low' io.writefile('/dev/usbctrl', state)
Check System config > Status > System log, you should see that USB converter is disconnected when the port is powered down. Similar to this:
Jul 7 11:17:03 LogicMachine kern.info kernel: [11838588.128976] cp210x 1-1:1.0: device disconnected Jul 7 11:17:03 LogicMachine kern.info kernel: [11838588.128729] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0 Jul 7 11:17:03 LogicMachine kern.info kernel: [11838588.128345] usb 1-1: USB disconnect, device number 4
Script reboot failing - by fbrun@domizy - 10.06.2024, 09:59
RE: Script reboot failing - by Daniel - 10.06.2024, 10:05
RE: Script reboot failing - by fbrun@domizy - 10.06.2024, 10:10
RE: Script reboot failing - by JMM - 24.06.2025, 14:21
RE: Script reboot failing - by Daniel - 24.06.2025, 14:42
RE: Script reboot failing - by JMM - 24.06.2025, 15:18
RE: Script reboot failing - by Daniel - 24.06.2025, 15:33
RE: Script reboot failing - by JMM - 24.06.2025, 15:48
RE: Script reboot failing - by Daniel - 24.06.2025, 15:53
RE: Script reboot failing - by JMM - 24.06.2025, 16:03
RE: Script reboot failing - by JMM - 24.06.2025, 17:28
RE: Script reboot failing - by admin - 25.06.2025, 07:17
RE: Script reboot failing - by JMM - 26.06.2025, 08:35
RE: Script reboot failing - by JMM - 04.07.2025, 10:09
RE: Script reboot failing - by Daniel - 04.07.2025, 12:42
RE: Script reboot failing - by admin - 07.07.2025, 11:20
