Ajax async comunication with AWS sqs
Try this code (adapted from https://stackoverflow.com/questions/7324...-version-4):
You will need to use socket.http and pass headers to the request.
require('encdec') local access_key = "XXXX" local secret_key = "XXXX" local method = 'POST' local service = 'execute-api' local host = 'dfadfadfdafda.execute-api.us-east-2.amazonaws.com' local region = 'us-east-2' local base = "https://" local content_type = 'application/json' local request_parameters = '{"date":"today","content":"hello"}' local canonical_uri = '/prod/events/add-event' -- DynamoDB requires an x-amz-target header that has this format: --     DynamoDB_<API version>.<operationName> local amz_target = '' function getSignatureKey(key, dateStamp, regionName, serviceName)   local kDate = encdec.hmacsha256(dateStamp, 'AWS4' .. key, true)   local kRegion = encdec.hmacsha256(regionName, kDate, true)   local kService = encdec.hmacsha256(serviceName, kRegion, true)   local kSigning = encdec.hmacsha256('aws4_request', kService, true)   return kSigning end -- ************* TASK 1: CREATE A CANONICAL REQUEST ************* -- http://docs.aws.amazon.com/general/latest/gr/sigv4-create-canonical-request.html -- Step 1 is to define the verb (GET, POST, etc.)--already done. -- Step 2: Create canonical URI--the part of the URI from domain to query -- string (use '/' if no path) -- Create a date for headers and the credential string local amz_date = os.date('!%Y%m%dT%H%M%SZ') local date_stamp = amz_date:split('T')[1] --// Step 3: Create the canonical query string. In this example, request -- parameters are passed in the body of the request and the query string -- is blank. local canonical_querystring = '' --## DOing step 6 first so that I can include the payload hash in the cannonical header, per https://docs.aws.amazon.com/AmazonS3/latest/API/sig-v4-header-based-auth.html -- Step 6: Create payload hash. In this example, the payload (body of -- the request) contains the request parameters. --local payload_hash = hashlib.sha256(request_parameters.encode('utf-8')).hexdigest() local payload_hash = encdec.sha256(request_parameters) -- Step 4: Create the canonical headers. Header names must be trimmed -- and lowercase, and sorted in code point order from low to high. -- Note that there is a trailing \n. local canonical_headers = 'host:' .. host .. '\n' .. 'x-amz-content-sha256:' .. payload_hash .. '\n' .. 'x-amz-date:' .. amz_date .. '\n' -- Step 5: Create the list of signed headers. This lists the headers -- in the canonical_headers list, delimited with ";" and in alpha order. -- Note: The request can include any headers; canonical_headers and -- signed_headers include those that you want to be included in the -- hash of the request. "Host" and "x-amz-date" are always required. local signed_headers = 'host;x-amz-content-sha256;x-amz-date' -- Step 7: Combine elements to create canonical request local canonical_request = method .. '\n' .. canonical_uri .. '\n' .. canonical_querystring .. '\n' .. canonical_headers .. '\n' .. signed_headers .. '\n' .. payload_hash -- ************* TASK 2: CREATE THE STRING TO SIGN************* -- Match the algorithm to the hashing algorithm you use, either SHA-1 or -- SHA-256 (recommended) local algorithm = 'AWS4-HMAC-SHA256' local credential_scope = date_stamp .. '/' .. region .. '/' .. service .. '/' .. 'aws4_request' local string_to_sign = algorithm .. '\n' ..  amz_date .. '\n' ..  credential_scope .. '\n' ..  encdec.sha256(canonical_request) -- ************* TASK 3: CALCULATE THE SIGNATURE ************* -- Create the signing key using the function defined above. local signing_key = getSignatureKey(secret_key, date_stamp, region, service) -- Sign the string_to_sign using the signing_key local signature = encdec.hmacsha256(string_to_sign, signing_key) -- ************* TASK 4: ADD SIGNING INFORMATION TO THE REQUEST ************* -- Put the signature information in a header named Authorization. local authorization_header = algorithm .. ' ' .. 'Credential=' .. access_key .. '/' .. credential_scope .. ', ' ..  'SignedHeaders=' .. signed_headers .. ', ' .. 'Signature=' .. signature -- For DynamoDB, the request can include any headers, but MUST include "host", "x-amz-date", -- "x-amz-target", "content-type", and "Authorization". Except for the authorization -- header, the headers must be included in the canonical_headers and signed_headers values, as -- noted earlier. Order here is not significant. local headers = {     ['X-Amz-Content-Sha256'] = payload_hash,     ['X-Amz-Date'] = amz_date,     -- ['X-Amz-Target'] = amz_target,     ['Authorization'] = authorization_header,     ['Content-Type'] = content_type } log(headers)
RE: Ajax async comunication with AWS sqs - by admin - 21.07.2025, 11:10
