Hue Brightness feedback
#81
Hello.
A few months ago, I integrated Philips Hue lighting fixtures that support dimming, color temperature change, and RGB. Everything works perfectly, except I hadn't set up the feedback for the light fixture's state if you change it from the Philips Hue app. Before posting on the forum, I carefully reviewed all topics related to this issue. I am using "user.hue v5.lua" and "resident hue feedback v2.lua". The on/off, dimming, and RGB feedback work perfectly. However, neither the color temperature change itself nor its feedback are working correctly. For example, I set 2000K from W4K, and in the Hue app, it shows a completely different color. The feedback also doesn't work. When I disable the feedback script, the color temperature control works correctly. I am using the following script. Please help me find where I am going wrong. I have spent over 2 days on this problem without a resolution.
Regards,
Nayden
-- Set name (Lookup in HUE app under light configuration) and feedback adresses (don't change statevalue, brivalue and colorvalue as they are used as memoryfield) addressmapping = {   -- Name                  -- On/Off FB       -- Bright FB   -- Color FB   ['Cove lighting-cr'] = {state = '1/0/9', bri = '32/2/9', rgb = '32/3/9', ct = '32/4/9', statevalue = '', brivalue = '', colorvalue = '', ctvalue = ''} } -- Set polling interval in seconds interval = 1 -- Use logging logging = false -- Load needed lib's require('user.hue') require('json') -- loop indefenitly while true do   reply = getHueLights()   mylamps = json.decode(reply)   for _, item in pairs(mylamps) do     -- Check if lamp is found by bridge otherwise it make no sense to send commands     if item.state.reachable == true then       -- On/Off       name = addressmapping[item.name]       if name then         addr = addressmapping[item.name]['state']         if addr and addr ~= '' then           currentvalue = addressmapping[item.name]['statevalue']           if currentvalue ~= item.state.on then             grp.write(addr, item.state.on)             addressmapping[item.name]['statevalue'] = item.state.on             if logging == true then               log('lamp ' .. item.name .. ' state is: ' .. tostring(item.state.on))             end           end         end       end       --Brightness       if item.state.bri then         name = addressmapping[item.name]         if name then           addr = addressmapping[item.name]['bri']           if addr and addr ~= '' then             -- Check if lamp is on otherwise overrule BRI value to 0             if item.state.on == false then               item.state.bri = 0             end             currentvalue = addressmapping[item.name]['brivalue'] or 0             if currentvalue ~= item.state.bri then               grp.write(addr, math.floor((tonumber(item.state.bri)/2.55) + 0.5))               addressmapping[item.name]['brivalue'] = item.state.bri               if logging == true then                 log('lamp ' .. item.name .. ' brightness is: ' .. math.floor((tonumber(item.state.bri)/2.55) + 0.5) .. ' %')               end             end           end         end       end            -- Color temperature       name = addressmapping[item.name]       if name and item.state.ct then         addr = addressmapping[item.name]['ct']         if addr and addr ~= '' then           newvalue = math.floor(1000000 / item.state.ct)           currentvalue = addressmapping[item.name]['ctvalue']           if currentvalue ~= newvalue then             grp.update(addr, newvalue)             addressmapping[item.name]['ctvalue'] = newvalue             if logging == true then               log('lamp ' .. item.name .. ' color temperature is: ' .. newvalue .. ' K')             end           end         end       end          --Color       if item.state.ct or item.state.xy then         name = addressmapping[item.name]         if name then           addr = addressmapping[item.name]['rgb']           if addr and addr ~= '' then             -- Check if lamp is on otherwise overrule color value to 0             if item.state.on == false then                colorvalue = 0             end             if item.state.colormode == 'xy' then               currentvalue = addressmapping[item.name]['colorvalue']               colorvalue = xy_to_rgb(item.state.xy[1],item.state.xy[2],item.state.bri)               --colorvalue = xyz_to_rgb((item.state.xy[1] * 100), (item.state.xy[2] * 100))               if currentvalue ~= colorvalue then                 grp.checkwrite(addr, colorvalue)                 addressmapping[item.name]['colorvalue'] = colorvalue                 if logging == true then                   log('lamp ' .. item.name .. ' color is: ' .. colorvalue)                 end               end             elseif item.state.colormode == 'ct' then               currentvalue = addressmapping[item.name]['colorvalue']               --colortemp = math.floor((item.state.ct / 0.0769) + 0.5)  --0.0769230769230769               colortemp = math.abs((item.state.ct - 500) / 2)               colortemp = math.floor(colortemp + 0.5)               colortemp = 80 + colortemp               if colortemp > 255 then                 colortemp = 255               end               r = lmcore.inttohex(255, 1)               g = lmcore.inttohex(255, 1)               b = lmcore.inttohex(colortemp, 1)               rgb = r .. g .. b               colortemp = lmcore.hextoint(rgb,3)               if currentvalue ~= colortemp then                 --colortempconverted = ct_to_rgb(colortemp)                 grp.write(addr, colortemp)                 addressmapping[item.name]['colorvalue'] = colortemp                 if logging == true then                   log('lamp ' .. item.name .. ' color is: ' .. colortemp)                 end               end             end           end         end       end     end   end   -- Delay loop   os.sleep(interval) end
Hue Brightness feedback - by Arjen Straver - 05.07.2017, 19:30
RE: Hue Brightness feedback - by Hippolyte - 19.07.2017, 15:14
RE: Hue Brightness feedback - by Hippolyte - 27.07.2017, 07:03
RE: Hue Brightness feedback - by Albertor - 21.11.2017, 18:22
RE: Hue Brightness feedback - by Albertor - 22.11.2017, 19:51
RE: Hue Brightness feedback - by DarthPaul - 13.08.2018, 12:19
RE: Hue Brightness feedback - by DarthPaul - 14.08.2018, 04:42
RE: Hue Brightness feedback - by admin - 13.08.2018, 12:40
RE: Hue Brightness feedback - by ralwet - 19.10.2018, 20:28
RE: Hue Brightness feedback - by FatMax - 30.11.2018, 16:36
RE: Hue Brightness feedback - by admin - 30.11.2018, 16:48
RE: Hue Brightness feedback - by FatMax - 01.12.2018, 02:58
RE: Hue Brightness feedback - by admin - 03.12.2018, 07:49
RE: Hue Brightness feedback - by FatMax - 03.12.2018, 07:59
RE: Hue Brightness feedback - by timchan054 - 02.01.2019, 01:13
RE: Hue Brightness feedback - by Daniel - 02.01.2019, 13:05
RE: Hue Brightness feedback - by lenze90 - 24.02.2019, 10:07
RE: Hue Brightness feedback - by Daniel - 25.02.2019, 09:13
RE: Hue Brightness feedback - by Zandkever - 21.08.2019, 09:02
RE: Hue Brightness feedback - by admin - 21.08.2019, 09:22
RE: Hue Brightness feedback - by Zandkever - 21.08.2019, 10:20
RE: Hue Brightness feedback - by Tee_Trinker - 08.05.2020, 22:31
RE: Hue Brightness feedback - by Tee_Trinker - 13.05.2020, 19:47
RE: Hue Brightness feedback - by Firechief - 08.06.2020, 16:16
RE: Hue Brightness feedback - by Firechief - 09.06.2020, 08:24
RE: Hue Brightness feedback - by Ravi Kiran S - 25.03.2021, 10:51
RE: Hue Brightness feedback - by MLa - 30.07.2020, 20:03
RE: Hue Brightness feedback - by MLa - 31.07.2020, 18:05
RE: Hue Brightness feedback - by Sral1987 - 02.08.2020, 17:25
RE: Hue Brightness feedback - by Sral1987 - 09.08.2020, 08:27
RE: Hue Brightness feedback - by Sral1987 - 05.09.2020, 15:48
RE: Hue Brightness feedback - by Sral1987 - 05.09.2020, 16:03
RE: Hue Brightness feedback - by Sral1987 - 01.05.2023, 08:44
RE: Hue Brightness feedback - by Firechief - 08.11.2020, 12:35
RE: Hue Brightness feedback - by admin - 09.11.2020, 08:23
RE: Hue Brightness feedback - by Firechief - 09.11.2020, 15:17
RE: Hue Brightness feedback - by admin - 09.11.2020, 15:45
RE: Hue Brightness feedback - by Firechief - 09.11.2020, 16:24
RE: Hue Brightness feedback - by admin - 09.11.2020, 17:13
RE: Hue Brightness feedback - by Firechief - 09.11.2020, 17:31
RE: Hue Brightness feedback - by admin - 09.11.2020, 17:45
RE: Hue Brightness feedback - by Firechief - 09.11.2020, 18:15
RE: Hue Brightness feedback - by Sral1987 - 27.11.2020, 17:36
RE: Hue Brightness feedback - by admin - 30.11.2020, 07:26
RE: Hue Brightness feedback - by Sral1987 - 30.11.2020, 15:59
RE: Hue Brightness feedback - by Sral1987 - 01.12.2020, 15:21
RE: Hue Brightness feedback - by Karaffe - 21.01.2022, 07:50
RE: Hue Brightness feedback - by Firechief - 25.03.2023, 14:56
RE: Hue Brightness feedback - by admin - 27.03.2023, 05:28
RE: Hue Brightness feedback - by Firechief - 28.03.2023, 07:47
RE: Hue Brightness feedback - by admin - 28.03.2023, 07:58
RE: Hue Brightness feedback - by Firechief - 28.03.2023, 09:31
RE: Hue Brightness feedback - by admin - 28.03.2023, 09:31
RE: Hue Brightness feedback - by Firechief - 28.03.2023, 09:35
RE: Hue Brightness feedback - by admin - 28.03.2023, 09:39
RE: Hue Brightness feedback - by Firechief - 28.03.2023, 09:41
RE: Hue Brightness feedback - by NKereshki - 20.04.2023, 11:32
RE: Hue Brightness feedback - by NKereshki - 20.04.2023, 13:38
RE: Hue Brightness feedback - by NKereshki - 24.04.2023, 06:33
RE: Hue Brightness feedback - by NKereshki - 23.07.2025, 11:31
RE: Hue Brightness feedback - by admin - 23.07.2025, 13:06
RE: Hue Brightness feedback - by NKereshki - 23.07.2025, 13:27
RE: Hue Brightness feedback - by admin - 23.07.2025, 13:38
RE: Hue Brightness feedback - by NKereshki - 23.07.2025, 13:42
RE: Hue Brightness feedback - by admin - 23.07.2025, 13:45
RE: Hue Brightness feedback - by NKereshki - 23.07.2025, 14:16
RE: Hue Brightness feedback - by Daniel - 23.07.2025, 14:25
RE: Hue Brightness feedback - by NKereshki - 24.07.2025, 08:26
RE: Hue Brightness feedback - by admin - 24.07.2025, 08:39
RE: Hue Brightness feedback - by NKereshki - 24.07.2025, 09:14
RE: Hue Brightness feedback - by admin - 24.07.2025, 09:22
RE: Hue Brightness feedback - by NKereshki - 24.07.2025, 12:40
RE: Hue Brightness feedback - by admin - 24.07.2025, 12:54
RE: Hue Brightness feedback - by NKereshki - 24.07.2025, 14:29
RE: Hue Brightness feedback - by Sral1987 - 28.07.2025, 05:45
RE: Hue Brightness feedback - by NKereshki - 28.07.2025, 11:18
RE: Hue Brightness feedback - by admin - 25.07.2025, 07:06
RE: Hue Brightness feedback - by NKereshki - 30.07.2025, 19:27
RE: Hue Brightness feedback - by stianj - 31.07.2025, 09:40
RE: Hue Brightness feedback - by Daniel - 31.07.2025, 07:37
RE: Hue Brightness feedback - by Sral1987 - 01.08.2025, 04:53
