25.07.2025, 09:19
(25.07.2025, 09:06)admin Wrote: There might be a problem if camera admin password contains special characters. Change it so it only contains letters and numbers. Put password into this script and run it.
Code:url = 'http://admin:PASSWORD@192.168.1.108/cgi-bin/snapshot.cgi?1&ts=123/snapshot.jpeg' local skthttp = require('socket.http') local skturl = require('socket.url') local ltn12 = require('ltn12') local md5sum = require('encdec').md5 local hash = function(...) return md5sum(table.concat({...}, ':')) end local parse_header = function(header) local result = {} for key, value in (header .. ','):gmatch('(%w+)=(.-),') do if value:sub(1, 1) == '"' then -- strip quotes result[ key:lower() ] = value:sub(2, -2) else result[ key:lower() ] = value end end return result end local make_digest_header = function(headers) local digest = {} for _, header in ipairs(headers) do if not header.unquote then header[ 2 ] = '"' .. header[ 2 ] .. '"' end digest[ #digest + 1 ] = header[ 1 ] .. '=' .. header[ 2 ] end return 'Digest ' .. table.concat(digest, ', ') end local _request = function(req) if not req.url then return nil, 'missing url' end local url = skturl.parse(req.url) local user, password = url.user, url.password if not user or not password then return nil, 'missing credentials in url' end url.user, url.password, url.authority, url.userinfo = nil, nil, nil, nil req.url = skturl.build(url) local source if req.source then local chunks = {} local capture = function(chunk) if chunk then chunks[ #chunks + 1 ] = chunk end return chunk end local chunk_id = 0 source = function() chunk_id = chunk_id + 1 return chunks[ chunk_id ] end req.source = ltn12.source.chain(req.source, capture) end local body, code, hdrs = skthttp.request(req) if code == 401 and hdrs['www-authenticate'] then local ht = parse_header(hdrs['www-authenticate']) if not ht.realm or not ht.nonce then return nil, 'missing realm/nonce from response' end if ht.qop ~= 'auth' then return nil, 'unsupported qop ' .. tostring(ht.qop) end if ht.algorithm and ht.algorithm:lower() ~= 'md5' then return nil, 'unsupported algo ' .. tostring(ht.algorithm) end local nc = '00000001' local cnonce = string.format('%08x', os.time()) local uri = skturl.build({ path = url.path, query = url.query }) local method = req.method or 'GET' local response = hash( hash(user, ht.realm, password), ht.nonce, nc, cnonce, 'auth', hash(method, uri) ) req.headers = req.headers or {} local auth = { { 'username', user }, { 'realm', ht.realm }, { 'nonce', ht.nonce }, { 'uri', uri }, { 'cnonce', cnonce }, { 'nc', nc, unquote = true }, { 'qop', 'auth' }, { 'algorithm', 'MD5' }, { 'response', response }, } if ht.opaque then table.insert(auth, { 'opaque', ht.opaque }) end req.headers.authorization = make_digest_header(auth) if not req.headers.cookie and hdrs['set-cookie'] then -- not really correct but enough for httpbin local cookie = (hdrs['set-cookie'] .. ';'):match('(.-=.-)[;,]') if cookie then req.headers.cookie = '$Version: 0; ' .. cookie .. ';' end end if req.source then req.source = source end body, code, hdrs = skthttp.request(req) end return body, code, hdrs end local request = function(url) local t = type(url) if t == 'table' then return _request(table.clone(url)) elseif t == 'string' then local req = {} local _, code, headers = _request({ url = url, sink = ltn12.sink.table(req) }) return table.concat(req), code, headers end end image, err, hdrs = request(url) log(type(image), err, hdrs)
Thank you, it works perfectly. The issue was caused by the camera password containing the
