Doorbell 2N IP (Intercom)
In last URL you have "valor" instead of "value".
Argument order does not matter:
> curl 'http://192.168.1.16/public/write.lp?addr=35/1/12&value=test' Addr: 35/1/12 Value: test Type: string Value: test > curl 'http://192.168.1.16/public/write.lp?value=test&addr=35/1/12' Addr: 35/1/12 Value: test Type: string Value: test
Same thing when testing via browser.
If you call grp.write(addr, value) without decoding value as JSON then string values don't need to be escaped. But then if you send "false" the resulting value will be true because the input is not a boolean but a string (1/0 can be used instead). Sending complex values like date/time won't be possible as well.
Doorbell 2N IP (Intercom) - by KNXSeb - 29.01.2022, 21:49
RE: Doorbell 2N IP (Intercom) - by KNXSeb - 30.01.2022, 13:23
RE: Doorbell 2N IP (Intercom) - by Daniel - 30.06.2025, 07:46
RE: Doorbell 2N IP (Intercom) - by Daniel - 30.06.2025, 10:59
RE: Doorbell 2N IP (Intercom) - by DGrandes - 11.09.2025, 13:37
RE: Doorbell 2N IP (Intercom) - by admin - 11.09.2025, 14:05
RE: Doorbell 2N IP (Intercom) - by DGrandes - 22.09.2025, 09:03
RE: Doorbell 2N IP (Intercom) - by DGrandes - 22.09.2025, 10:39
RE: Doorbell 2N IP (Intercom) - by admin - 22.09.2025, 10:43
RE: Doorbell 2N IP (Intercom) - by DGrandes - 22.09.2025, 13:53
RE: Doorbell 2N IP (Intercom) - by admin - 22.09.2025, 14:25
RE: Doorbell 2N IP (Intercom) - by DGrandes - 22.09.2025, 15:56
RE: Doorbell 2N IP (Intercom) - by admin - 23.09.2025, 08:17
RE: Doorbell 2N IP (Intercom) - by DGrandes - 23.09.2025, 11:22
